Author: Subject: Emerald ecu
dilley
posted on 13/9/15 at 04:30 PM Reply With Quote
Emerald ecu
I've had a great day today, got my car running...s2000, emerald Ecu. The ecu came loaded with a base map, I had lots of backfiring on initial startup. After some tinkering with fueling/ignition etc, I managed to get the engine ticking over and running ok ish. I'm assuming that a rolling road session is required for fine tuning? How well should they run prior to this?
Dilley
Ugg10
posted on 13/9/15 at 04:42 PM Reply With Quote
If you have a wideband lambda system you can feed the 0-5v linear output into the emerald and either run it closed loop or put in a desired lambda map and after running for a bit will tell you what to change the injection to in order to meet it. Either of these will get you close but to squeeze the last few hp/lbft out ofnthe engine a roling Road session will be needed.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
posted on 13/9/15 at 04:43 PM Reply With Quote
When I installed my Emerald ECU onto my rebuilt and modified engine I managed to get it running well enough to drive the car while my brother sat in the passengers seat operating the laptop . I don't know if the later ECU s still have the ability to show a bullseye target for the load and speed sites along with a bar graph showing the mixture but on mine it does . I drove at steady load and speed whilst my brother adjusted as required , did every other site then inter polluted ( if that's the right term) to set the unset sites Got it good enough to safely get a few miles on the new engine before getting it onto the RR . Dave at Emerald told me the sites I had set were pretty good . If your intending on taking the car to Emerald get it booked in ASAP
dilley
posted on 13/9/15 at 05:10 PM Reply With Quote
Unfortunately I do not have a lambda installed!
mark chandler
posted on 13/9/15 at 05:39 PM Reply With Quote
Out the box setting will be safe, rich and retarded so good enough to get to the rolling road, suggest you bite the bullet and see John at Emerald to set up.
First thing, get a strobe and make sure with 0 advance its on TDC
posted on 13/9/15 at 08:25 PM Reply With Quote
So is the base map generic enough to work on any engine? I'm working towards a EFi conversion of my bike engine. I was planning on strobing a timing wheel on the crank to work out the stock ECU timing 2D map and putting that into an Emerald ECU but if the stock map is good enough I won't bother. I'll just drive it to them for a proper rolling road session
posted on 14/9/15 at 09:32 AM Reply With Quote
A usable base map (i.e. good enough to get the engine running) will be specific to the engine displacement, injector flow rate etc. There is no such thing as a map that will allow any engine to run.
Ugg10
posted on 14/9/15 at 11:01 AM Reply With Quote
Agree with MikeRJ, the best bet is to call Emerald, let them know the engine and spec and there is a goo likelihood they have mapped something pretty similar and so can email you a base map to work from. This will get you to the mapping session or can be optimised on the road with the help of a wide band lambda system.
[Edited on 14/9/15 by Ugg10]
dilley
posted on 14/9/15 at 12:22 PM Reply With Quote
Emerald supply a dedicated map for the engine.
I have found a problem....cam gear that runs both cams has Sheared its bolt, luckily I found out at this stage and not 9000rpm!
