Author: Subject: Tiger Avon loom
locost7-online.com
posted on 13/9/15 at 08:05 PM Reply With Quote
Tiger Avon loom
Can anyone tell me if the brands hatch 12 circuit loom will work in a tiger Avon with a bike engine? Or can anyone recommend one to use or do I just stick with getting a tiger one?
Locost Xflow 150bhp injected! Sold :-(
Facebook blog https://www.facebook.com/Johns-Tiger-Avon-Build-814223212056368/
PLEASE NOTE THIS MEMBER IS NOT A TRADER.
jossey
posted on 14/9/15 at 03:46 PM Reply With Quote
I've used the tiger one in the end. spend a few hours labelling and it will be fine.
I haven't used the engine loom section which goes to the alternator wire not the majority of the lights switch part of the loom.
I have the loom working on my Avon with fire blade and only used fireblade loom for ecu power and coils power and the parts from clutch neutral switch and oil pressure.
It's a good loom and light and relays are pre wired.
It's the cat loom I think.
They may have a new diagram as the old one takes a few hours to label up.
With mine I ran the loom opposite side to what it's made for so may indicators are backwards this is to avoid the exhaust as the wire is made to run down the left side.
Just switch the indicator round and your there.
David Johnson
jossey
posted on 16/9/15 at 05:57 AM Reply With Quote
I've emailed you
David Johnson
locost7-online.com
posted on 16/9/15 at 08:10 PM Reply With Quote
Got mail thanks, a lot neater in second pic, the brands hatch loom is 12 circuit and has pre wired relays and fuses, I was going to tidy up the blade loom and reuse it
eBay item no. 111648991317
Looks ok to me but not sure
jossey
posted on 16/9/15 at 09:13 PM Reply With Quote
Looks good. Only bits you need from your blade is the coils to fuse, neutral, oil pressure and the negatives. I did use the starter relay but cut into the main loom.
Good luck but Ye that loom should work.
Dave
David Johnson
