Author: Subject: custom tie rods info needed
d8vyr
posted on 15/9/15 at 09:13 PM Reply With Quote
hi all, i`m needing to reduce my escort steering tie rods about 15mm... anyone know who does shorter tie rods or adjustable tie rods...OR any other way i might sort the problem out
cheers davy
CosKev3
posted on 16/9/15 at 08:03 AM Reply With Quote
Cut them down and recut the thread?
posted on 16/9/15 at 11:13 AM Reply With Quote
You can't do that on Ford M14x2 tie rods as the thread form is rolled into the tie rod which is 1/2" (12.7mm) dia bar stock.
pre lit
posted on 16/9/15 at 12:07 PM Reply With Quote
cut them down thread to m10 and use rose joints
posted on 16/9/15 at 08:02 PM Reply With Quote
10mm dia is not a good idea. No production car has steering tie rods of less than 12.5 mm dia. Thinking it of as tie bar is misleading in design terms the failure mode for a steering track rod is buckling under compression, for stress analysis purposes it fits Euler's model of a slim strut with pinned ends.
CosKev3
posted on 17/9/15 at 07:09 AM Reply With Quote
Ah right.
Remove 15mm from further inboard,machine out holes in the centre and press in some smaller diameter bar and then weld it up be a option?
