Author: Subject: koso rpm help
ianminki
posted on 17/9/15 at 11:04 AM Reply With Quote
koso rpm help
hi all
looking for some help with rpm setting's on my koso rx2n as the reading is very unstable once out on the road.my car has a 893 fire blade engine. the reading is steady when ticking over but becomes very unstable when accelerating . I have used the ecu for rpm output is this right
regards ian
craig5
posted on 4/10/15 at 06:16 PM Reply With Quote
Where have you taken the feed from?
theduck
posted on 4/10/15 at 06:23 PM Reply With Quote
Have you put a resistor inline?
CosKev3
posted on 4/10/15 at 08:04 PM Reply With Quote
My koso connected to my R1 is like this.
Wouldn't work at all using feed from CDU to clocks,so connected it into wiring from the coil packs as per koso instructions.
Interested in the resistor mentioned above?
craig5
posted on 4/10/15 at 08:11 PM Reply With Quote
I'm from coil and at 1st the revs had life of there own so I shielded the wire and revs are now perfect
CosKev3
posted on 4/10/15 at 08:19 PM Reply With Quote
Will try that cheers.
craig5
posted on 4/10/15 at 08:23 PM Reply With Quote
I'm only in n Wales can get some great shielding in work if u want to get it
theduck
posted on 4/10/15 at 08:28 PM Reply With Quote
On my acewell I had to put a 1m ohm resistor in line to get a smooth reading.
As mentioned, shielding is the other common issue. Best using coax cable (aerial cable) use the core for signal and the connect the outer to earth.
Fill589
posted on 25/11/15 at 07:47 PM Reply With Quote
Mine does the same I find running with side lights on stops it ?
DRM Black7
posted on 25/11/15 at 08:06 PM Reply With Quote
I had a similar problem with an Etb rev counter, very unstable rpm and bouncing all over the place. Spoke to etb and they surjested this diode,
http://www.maplin.co.uk/p/1n4007s-1a-silicon-rectifier-ql79l
I had already tried a resister.
The Diode did the trick
