Nickp
| posted on 23/10/15 at 09:52 AM |
Enough sag?
I've been cutting the holes in my side panels for the suspension etc to poke through and trial fitted the suspension to check clearance. I was a
bit surprised to only have a very slight amount of downward tilt of the bottom wishbone when the shock is fully extended. It's only about 3deg,
does this sound OK? The shocks are the recommended length for a Haynes at 13" open IIRC.
Stot
| posted on 23/10/15 at 02:26 PM |
if you have 13" open shocks you need a 1" extension as the original book got it wrong.
Book Updates Link
10. Damper lengths In the book we suggest 13in open, 9in closed damper s. Doing a little work on the suspension geometry, I’ve discovered that a
one-inch extension on the top of the dampers would allow more “droop” movement, without affecting the “bump” . This will give better performance on
bumpy surfaces (read every road in Britain!). The dampers would still be 13in open, 9in closed, b ut with a one-inch solid extension fitted to the
top. Both Dampertech and Protech produce this t ype of damper.
Many people just buy 14"open 1.9" shocks, Thats what I have at the front of mine and they fit fine.
If you got them from Rally Design they are pretty good if you want to exchange them.
Stot
Nickp
| posted on 23/10/15 at 05:33 PM |
Book Updates Link
Stot
Well that's a bit of a bugger!! When I got the 'car' (boxes of bits and a chassis) the AVO shocks that came with it were 12"
and 14" open. So I sent them to AVO, they serviced them and 'corrected' the lengths both to 13". I've just checked and
all the shocks only have 3.5" of travel and then have a 1" bumpstop fitted making that more like 2.5" of travel!! So I've just
made up a 14" one by swapping the tops. Now I have about 10deg of sag/droop but only about 5deg of bump before it hits the bumpstop Is a
1" bumpstop normal or total overkill?
Am I flogging a dead horse with these AVOs and their 3.5" of travel or can they be made to work?
Update- With the bumpstop removed completely I now have a 10deg swing up and down which looks a lot more like it. So do I need bumpstops at all? Or
just trim them down to the bare minimum?
[Edited on 23/10/15 by Nickp]
