Author: Subject: Long shot Puma Plug Pin Outs
Ugg10
posted on 26/10/15 at 01:38 PM Reply With Quote
I know this is probably a long shot but before I spend a tedious evening with a multimeter bleeping out my wiring, does anyone have the pin outs for the Ford Puma 1.7 (VCT) engine loom main plug (connects to the injectors, sensors etc., large square multiway plug), really usefully Mr. Ford has used all black wires on both sides of the plug !
Thanks in advance.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
pewe
posted on 26/10/15 at 02:49 PM Reply With Quote
Just in case you aren't aware of it Pumapeople might help?
Cheers, Pewe10
theprisioner
posted on 26/10/15 at 03:11 PM Reply With Quote
I have one for the ecu that largely goes to the engine loom in Open Office (.ods) format but can be saved in exel or pdf format. PM your email address if you want it.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
Ugg10
posted on 26/10/15 at 03:36 PM Reply With Quote
Many thanks for the replies, will try and post something on puma people and thanks for the offer ThePrisoner but I am hoping to use the OEM engine end of the loom and connect it to an Omex 710 flying loom. I have chopped off the engine bay loom car side of the multiway connector but as previously said all of the wires in this part of the loom are black (genius Mr. Ford). Looks like a night in with me, the loom and a bleeper !
I will have to do the same for my Escort Mk2 column stalks as well to splice into my Pemier Looms wiring, oh what fun I have.
theprisioner
posted on 26/10/15 at 06:31 PM Reply With Quote
I have the Ford (Technical Information system) TIS disc. It has the complete workshop manual including the electrical system. I guess a binary copy is possible not sure how (yet) ----I think you need two disc drives tho!
monkeyarms
posted on 27/10/15 at 01:26 PM Reply With Quote
You just need an image burning software package - Like IMGburn
It will copy the disc to a .ISO file on your PC, then you can either send the file of reburn the file to a blank disc. Simple.
I could do it, but my copy is at home, and i am in the philippines right now for 3 weeks!
