AdamR20
| posted on 28/10/15 at 10:10 AM |
MX-5 VLSD Chain Drive Conversion
Morning all,
I'm looking to convert an early 1.6 MX-5 VLSD to chain drive and wondering if anyone has any pearls of wisdom?
I've checked out the (probably deliberately fairly small ) photos on chaindrivediff.co.uk and think I know how they are doing it, but the bit
I'm struggling on is sealing the unit up - mainly the side of the flange where the crownwheel is normally fitted, the holes circled red
below:
Here are some other pics:
The 'cup' that goes over the main body of the diff looks like a right bugger to make - a LOT of boring / machining - but I guess it would
be possible to do it in steel instead, using a piece of tube of the right ID and then weld a 'cap' over the end.
But yeah, anyone else done this conversion and willing to share how they did it?
Many thanks in advance,
Adam
minitici
| posted on 28/10/15 at 10:36 AM |
Simple - send the bits to me to convert - as you can see I have done a few!
Doug (AKA Westgarage Engineering)
AdamR20
| posted on 28/10/15 at 10:40 AM |
Haha. I actually just sent you an email asking for prices. I'll give you a call if it's easier Thanks.
russbost
| posted on 28/10/15 at 03:18 PM |
We convert the standard MR2 Mk1 donor diff for use in the Furore, the first ones I had an ali "can" machined up similar to what
you've pictured, which was bl**dy expensive, on all after the first couple we simply get plates welded into the gaps in the casing & have a
bung & grease nipple, fill the diff with grease - I've not managed to break one yet with a ZZR1400, so the principle certainly works!
It's simpler, cheaper & significantly lighter.
maccmike
| posted on 28/10/15 at 04:49 PM |
hahaha
