will121
posted on 1/11/15 at 11:22 AM |
Zetec compression tester question
I've got a gunston compression tester but will not screw into the plug hole on a Zetec, it appears that the Zetec plugs are a deep seated type
where the thread doesn't start at the top of the hole so thread on tester is to short, any ideas or do I need to buy another tester specific for
a Zetec"
Andi
posted on 1/11/15 at 01:50 PM |
Loads of places online like ebay and amazon to name a couple
Long Reach Compression Tester Adaptor 3781![](http://rover.ebay.com/roverimp/1/710-53481-19255-0/1?ff3=2&pub=5574934589&toolid=10001&campid=5336738914&customid=&item=123456&mpt=[CACHEBUSTER])
posted on 1/11/15 at 01:52 PM |
a Zetec"
By a set that as well as as a selection of threaded adapters includes rubber cone type fittings as these are universal provided you have an assistant
to crank the engine for you.
Also if you have compressor consider a cylinder leak down tester as these are more useful for identifying the cause of cylinder leakage.
[Edited on 1/11/15 by britishtrident]
