Author: Subject: Caterham 6 speed box gear position extended
Hornet
posted on 1/11/15 at 03:01 PM Reply With Quote
Hi guys as per the title, has anyone extended the position? I see rally design do a type 9 which is for a 4 or 5 speed but not sure if that will work. Any help appreciated.
Paul Turner
posted on 2/11/15 at 11:06 AM Reply With Quote
The Caterham 6 speed box uses the same lever as the 5 speed type 9.
No such thing as a Type 9 4 speed, its the type E which normally uses a screw in lever. Very late in the type E's life there was a version used in the Sierra that used a type 9 lever but it was a mongrel of a box that has very limited compatibility with other Ford boxes. Most had cast in bellhousings (like the type 2) and internals are different to such an extent that aftermarket gear kits won't fit. Think it was Fords last throw of the dice before the 5 speed became standard across all models.
