<<  1    2  >>
Author: Subject: Hans device
ali f27
posted on 11/11/15 at 06:26 PM Reply With Quote
Hans device
Hi collective were is the cheapest place to get a hans device
jeffw
posted on 11/11/15 at 06:37 PM Reply With Quote
What angle do you want? 20deg is much cheaper than 30deg.
Have a look at Plays Kool
http://www.plays-kool.co.uk/acatalog/Hans-Devices---Accessories.html
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
Bought mine from Ed Moore cost me 245 for a 20degree model hans......
danny keenan
posted on 11/11/15 at 06:56 PM Reply With Quote
Hi
If I had a group buy of 10 I could do them at 235 with free delivery
Thanks Danny
richard munnis
posted on 11/11/15 at 07:59 PM Reply With Quote
Hans
I would be number one of ten
unijacko67
posted on 11/11/15 at 08:12 PM Reply With Quote
I may be number 2 if I can get a 20 degree one to work, need to borrow one first.
http://www.kittenkitcar.co.uk
MsD
posted on 11/11/15 at 08:52 PM Reply With Quote
I would consider one.
At the NEC this weekend so will try a few sizes on.
What's everyone doing about belts? Do we need HANS approved ones? If so any offers on Danny?
Mark.
daniel mason
posted on 11/11/15 at 09:14 PM Reply With Quote
You don't need hans specific belts to use a hans.but if you do use hans specific belts then you MUST wear a hans!
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
posted on 11/11/15 at 09:27 PM Reply With Quote
You beat me to it Dan. So many people are getting confused about this rule and it is quite simple really. Just use the 3" ones you have and dont be conned into buying 2" HANS belts, because if you leave the hans at home, thats where you will be going. I and others still use our 3" belts and in my case with a 20 degree in my single seater. Works a treat and cheap.
mark chandler
posted on 11/11/15 at 10:09 PM Reply With Quote
I need one for next year, 235 sounds good if you can make the numbers
jeffw
posted on 12/11/15 at 07:25 AM Reply With Quote
In most situations people need a 20 Deg Medium HANS. 30 Deg is really for formula cars and Large is 18" neck or bigger.
So 20 Deg Medium using your existing, in date, 3" harness is the cheapest way to do it. You will also need to make sure your Helmet is approved for use with FHR.
Norfolkluegojnr
posted on 12/11/15 at 08:59 AM Reply With Quote
I'd be in as well for a group buy.
How many is that? 6?
spdpug98
posted on 12/11/15 at 09:50 AM Reply With Quote
I could also be in for this too....
My Blog: http://spdpug98.wordpress.com/
jeffw
posted on 12/11/15 at 10:38 AM Reply With Quote
Just a few points for anyone looking to buy a HANS/FHR.
1. If you wear one the belts need to be racing tight, as in almost can't breath tight.
2. Side vision is quite restricted as you can't easily rotate your head.
3. You need a current spec car racing helmet with posts already fitted to ensure the HANS will work.
4. HANS tends to be uncomfortable to wear for long periods and can cause issues getting out of vehicles (tends to catch the rear of the yoke).
5. Currently the MSA does not require FHR/HANS for Road Going cars in Sprinting.
6. You need a 4 belt harness minimum (ideally 6) which has been fitted in accordance with HANS/FHR spec. The rear belts must be level with your shoulders or slightly below. If the belt mounts are above your shoulders HANS will not work.
7. HANS offers no side impact protection at all, it is a Front Head Restraint after all.
So if you are looking to buy and use one please make sure your belts are suitable and correctly fitted and that your helmet is to the correct specification.
Norfolkluegojnr
posted on 12/11/15 at 10:48 AM Reply With Quote
Sorry for the highjack - Jeff, am I safe to use my current 3" 4 point Sabelts? I'd hate to have to change them as well as a new helmet and FHR for the new season!
Belts are in date, and were replaced two years ago.
jeffw
posted on 12/11/15 at 11:02 AM Reply With Quote
Yes, they will be fine assuming they are fitted as per the HANS instructions.
http://www.msar.co.uk/pdf/HansUSAOwnersManual.pdf
Read and digest, especially the belt fitment.
[Edited on 12/11/15 by jeffw]
Norfolkluegojnr
posted on 12/11/15 at 11:08 AM Reply With Quote
thanks
Other than the belts being quite long (its a clio and they attached under the cage) I should be fine.
[Edited on 12/11/15 by Norfolkluegojnr]
jeffw
posted on 12/11/15 at 11:38 AM Reply With Quote
If they are long you may need to cross them behind the seat to get the correct angle. Long belts obviously stretch more than short belts (1 inch per foot rings a bell for some reason) in an accident and can allow the HANS to lift off the shoulders.
jtskips
posted on 12/11/15 at 05:14 PM Reply With Quote
I am in the market for a 20 degree hans device , I really wanted to get one after Christmas but if there is bulk purchase discount available somewhere then i`m in
Lordyplums
posted on 12/11/15 at 06:08 PM Reply With Quote
I'd be in for one on a bulk buy :-)
AdamR20
posted on 12/11/15 at 06:35 PM Reply With Quote
I've been using a Stand21 20 Degree Medium for a few seasons, but now looks like I'll need an adjustable one - so happy to move it on if anyone wants it.
lsdweb
posted on 12/11/15 at 06:39 PM Reply With Quote
I'd be in for one too.
Wyn
danny keenan
posted on 12/11/15 at 08:22 PM Reply With Quote
To my count there is 7 people who are interested in the Hans.so we only need 3 more to get the bulk buy.
If those who are interested could send me a U2u with there name and contact number.i will contact you ASAP
Thanks Danny
daniel mason
posted on 12/11/15 at 10:34 PM Reply With Quote
Stand 21 Club hans Device FIA Approved 20° recline (Med/Large) Race Rally Track
jtskips
posted on 13/11/15 at 06:26 PM Reply With Quote
http://www.vulcanracing.co.uk/apps/webstore/products/show/5635823
233ea ,,,, not asked for multi buy discount yet
<<  1    2  >>
