Author: Subject: Type 9 leak
beaver34
posted on 14/11/15 at 02:38 PM Reply With Quote
Type 9 leak
hi,
ive got a weeping type 9, collect at the bottom of the middle of the box, dry bell housing, dry at the rear where prop goes in, presume it will be the gasket or seal between the tail ans the main box section?
is it an easy fit, are there guides online to how to rebuild?
finally where to get the gaskets from burton power?
thanks
posted on 14/11/15 at 04:09 PM Reply With Quote
Decent quality instant gasket will do the job but check the leak isn't from the speedo drive, also the leak isn't from under the bolt heads. there are also reports of cracked tailshaft housing if the engine is solid mounted.
Pete Jordan
posted on 14/11/15 at 06:06 PM Reply With Quote
Its reasonably easy if its the tail housing seal but if its the sandwich plate to main housing seal that's a bit more involved. I have photos of the rebuild I did on my type 9 in my photo archive. Full instructions are in the Sierra Haynes manual if you have an early enough one. I think I may have a pdf of the gearbox chapter if you haven't. Oh, and you can buy gasket sets on EBay, probably cheaper than Burton Power.
Hope that helps,
Pete
beaver34
posted on 14/11/15 at 06:50 PM Reply With Quote
purchased a new seal and gasket set so ill pull it apart and do them all, and give the gaskets a smear of instant gasket to be sure
