beaver34
| posted on 8/12/15 at 07:27 AM |
garage and gate remote help
hi,
just fitted some electric gates to the house and we already have an electric roller door.
i want one remote to do both, i know the gates are 433 mhz but i dont know what the door is, how can you find out?
there is nothing in the box to say or on the remotes at all.
any tips?
thanks
bi22le
| posted on 8/12/15 at 08:17 AM |
IIRC every consumer item is 433Mhz. Its the exact frequency which will be hard.
Split a remote case, quite often there is a sticker inside staying the frequency.
A 3rd party remote system may be able to match the code and then just replicate it.
Please read my ring story:
beaver34
| posted on 8/12/15 at 08:38 AM |
nothing inside the case i had it apart last night
mazie
| posted on 8/12/15 at 09:43 AM |
I think Bizzle is thinking of car remote fobs, not commercial access control, these can be varying frequencies based on manufacturer, batch, model,
range and a country of origin.
If you can take a picture for me I may be able to help Identify. I work in access control design and manufacturing, we do a few of these ourselves .
beaver34
| posted on 8/12/15 at 09:47 AM |
thanks!
hizzi
| posted on 8/12/15 at 09:48 AM |
finding the frequency is fairly easy with a frequency counter cheap from amateur radio suppliers, the problem you have is the frequency will also have
some kind of tone encryption added to it, finding that requires more techical equipment and gets stupid.
you may be better asking the company that supplied your doors if they can link them, but is suspect not
joneh
| posted on 8/12/15 at 09:52 AM |
Just glue the two remotes together. Locost!
hizzi
| posted on 8/12/15 at 09:59 AM |
another thought, instead of messing with the remotes. these controls will ultimatley have a power output to the door or gate motor, could you take a
feed off that through a relay and run a cable to the gate motor?
tegwin
| posted on 8/12/15 at 10:04 AM |
Take the innards out of both remotes and then have a case 3D printed that holds them both inside
www.verticalhorizonsmedia.tv
mazie
| posted on 8/12/15 at 10:18 AM |
fairly sure that is going to be 433 ( default Euro low security stuff)
sorry here is no way to tell exactly. Theoretically it could be 318, 418, 295 mhz.
I take it you've tried to teach the controller to 'learn' your existing fob? normally this is a simple matter of pressing a learn
button for every button on the fob . Or could be that one is rolling code and the other a fixed code.
Ben_Copeland
| posted on 8/12/15 at 11:52 AM |
You can buy garage door remote clones from ebay sellers. I use a nice sliding front chrome one for my garage door.
You just hold them together press the old remote while telling the cloner to clone. Can run several remotes in one.
Worth a try they aren't expensive
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
