Author: Subject: Single wiper arm measurement needed. Audi A2/Citroen C1/Peugeot 108
KFC
posted on 13/12/15 at 12:33 PM Reply With Quote
I'm not far away from being done my V6 swap, there's light at the end of the long bendy tunnel!
I've had to change my scuttle panel again because I want my trumpets to be as long as possible so I've moved the wiper pivot point to a single arm setup. I've used my stock one as a mock up and it could be better with an Audi A2 single arm type. It has a double arm to alter the attachment head where the blade attaches to change the angle at the end of the sweep. Before I buy an arm, it would be nice to know how long it is, if it's worth going for. Others that are similar are the Citroen C1 and the Peugeot 108.
My wiper arm measuring from where it bolts on to the pivot to the end where the wiper clips in is 50cm. I reckon it should be about 58cm long with a 23" wiper.
Has anyone got any measurements?
DW100
posted on 13/12/15 at 03:04 PM Reply With Quote
Just been out and measured my daughters 107 (same as C1 and Toyota Aygo)
Arm is approx 22 1/2 inches (570mm) from pivot to blade mount, with a 26" blade.
[Edited on 13/12/15 by DW100]
KFC
posted on 13/12/15 at 11:21 PM Reply With Quote
Ah wow! Looks like that's the one then. I'll look for one close to me.
Thanks for the info!
