Author: Subject: Omex 600 ecu / Type 9 Gearbox
mrwibble
posted on 29/1/16 at 05:25 PM Reply With Quote
Decided to split the most desirable parts of my project and sell separately the ECU & type 9 gearbox.
Omex 600 ECU - New/Unused in original omex box & includes Omex stickers (yay!) £500
Type 9 gearbox - from F reg Sierra 1800 L. mileage 80k. Last MOT scrappage paperwork available for proof of mileage. £225
These are both also for sale on Ebay.
Ford Sierra Type 9 5 Speed Gearbox only 80k Miles MOT & Scrappage Paperwork
Omex 600 4 Cyl Semi Sequential ECU New/Unused In Box LOWER PRICE
Will post out ECU, type 9 is collection only DY10 postcode.
[Edited on 29/1/16 by mrwibble]
Mark100
posted on 29/1/16 at 08:56 PM Reply With Quote
wireing loom ?? was looking for an ecu that will do vvt on an st170 engine but could go blacktop easily
mrwibble
posted on 29/1/16 at 09:03 PM Reply With Quote
You'll need to buy a loom separate. This will do your vvt no problem though. You can pick up a new semi assembled loom on ebay £60.
J90rdn
posted on 29/1/16 at 09:36 PM Reply With Quote
Did you catch the mouse?
mrwibble
posted on 29/1/16 at 09:39 PM Reply With Quote
Haha. Yeah. I'll throw the little nipper in if you want box.
J90rdn
posted on 29/1/16 at 09:46 PM Reply With Quote
Would have jumped at the box few weeks ago. Picked up a scrapper for £100 and spent nearly £200 on new bearing, seals and gaskets. Ho hum. Someone will be getting a good deal.
kingster996
posted on 30/1/16 at 09:07 AM Reply With Quote
Ones 710 does vvt so does the dta s60, s80. The 600 will suit a blacktop, but can't fully control the vvt on the st.
I used to be indecisive, but now I'm not so sure
mrwibble
posted on 30/1/16 at 09:25 AM Reply With Quote
Excuse me if I misunderstood variable cam control as vvt? Full spec list http://omextechnology.co.uk/page75.html
[Edited on 30/1/16 by mrwibble]
mrwibble
posted on 30/1/16 at 10:16 AM Reply With Quote
Mark100. Seems like the pros & cons of vvt have been well debated here: http://www.locostbuilders.co.uk/viewthread.php?tid=165372
kingster996
posted on 30/1/16 at 12:55 PM Reply With Quote
It may do VVT but not the same way the st170 requires in order to fully utilise it. Well documented on many threads on here
mrwibble
posted on 3/2/16 at 08:01 PM Reply With Quote
Box now sold. Ecu still for sale looking for £475.
Cheers Ed
Jenko
posted on 4/2/16 at 10:35 AM Reply With Quote
It will turn the VVT / VCT on or off, but crucially allows you to turn it on then off again at higher rpm where its not needed. It does work though, I've done it on a puma engine using an OMEX600 with great results.
MY BLOG - http://westfieldv8.blogspot.co.uk/
mrwibble
posted on 17/2/16 at 01:43 PM Reply With Quote
ECU & Type 9 SOLD
Thanks for interest. Both ECU & Box are now sold.
Fury Rolling chassis is & zetec 2lt is available separately. Looking for £1150 to clear quickly, or else I will start to split it up and sell individually.
See here if you are http://locostbuilders.co.uk/viewthread.php?tid=202237
massive bargain, if you are interested in building a fury sportscar.
Thanks again
Ed
