Author: Subject: Raceline Water Rail and Expansion Tanks
AntonUK
posted on 31/1/16 at 09:30 PM Reply With Quote
In my 1.8 silvertop I have the raceline water rail fitted. Love em or hate them it was standard fit on my car so I'll be going ahead with using it.
I purchased one of these as its expansion tank.
Polished All Aluminum Radiator Coolant Overflow Recovery Bottle Tank Universal
The rails overflow (the small pipe used when the pressure cap in the water rail activates) is plumbed to the bottom port of the tank and the top port of the tank is blanked off. The expansion tank cap is a no pressure relief type and us essentially just a screw top.
Is this correct / safe to use?
My possible incorrect thinking is.. if/when the pressure cap in the rail activates and fills the expansion tank, if the pressure kept increasing there is nowhere for the excess pressure to go and would result in a popped hose or gasket? Right/Wrong?
Build Photos Here
arrow-engineering
posted on 31/1/16 at 09:50 PM Reply With Quote
the cap on the expansion tank takes care of the pressure. with a raceline rail you need a small barbed union (same size as the small pipe on the expansion tank) you run a hose from the barb to the top of the tank, this will be mostly air, together with the air in the tank. the feed from the expansion tank should enter the cooling system low down on the water pump to rad hose.
AntonUK
posted on 31/1/16 at 10:26 PM Reply With Quote
Isn't that the setup for a header tank not an expansion tank?
Build Photos Here
cliftyhanger
posted on 1/2/16 at 07:44 AM Reply With Quote
In your setup the expansion bottle should vent to atmosphere.
And as long as the rad cap on the water rail is working correctly, as the engine cools the coolant should be sucked back.
However, with the water rail I found it worked best by using a header tank and changing the rad cap for a seal cap (or a rad cap with the gubbins cut out) along with a couple of 3mm holes in the thermostat. Temperature was very stable with that, and none of the reported "issues" people regularly post about. I believe that is because it allows water flow right up to the thermostat rather than leaving the water rail full of static or slow moving water.
jeffw
posted on 1/2/16 at 11:08 AM Reply With Quote
I have a plastic expansion tank with a clip type lid. In normal operation (once the rail has found its water level) the tank is never warm so I doubt you will see any issues with your setup.
Raceline suggest just having a waste pipe down under the engine for any water overflow but I erred on the side of safety and pretty much did what you are suggesting.
AntonUK
posted on 2/2/16 at 07:38 AM Reply With Quote
That's good to know. Does that clip lid have a small hole in it?
Build Photos Here
jeffw
posted on 2/2/16 at 09:28 AM Reply With Quote
No. it it just a plastic push fit lid. A vent in your screw lid might be a good idea.
AntonUK
posted on 2/2/16 at 07:21 PM Reply With Quote
Cheers a perfect excuse to try out the drilling ability of my new mill
Build Photos Here
