Author: Subject: Interesting parts for sale
ephemera
posted on 2/2/16 at 01:30 PM Reply With Quote
Hi all, I am new to this forum and hope to contribute more in the future. I have two Fury's and two TVR Vixen's, all modified of course. The parts that I have for sale now can hopefully go to a good home to assist in your projects. All items are new or in vgc. They are priced to sell (< half new price or rightout cheap) because our hobby needs to be fun ;-) Enjoy, and contact me if you need pics or more info.
Koni Racing shocks and springs, pair
Carbon airbox and alu backplate
Caterham differential 3.92 non LSD, as new
Caterham driveshafts, new
Carbon canards/winglets
Willwood superlites, huge vented discs, separate bells, pair
Goodridge hoses, various, some braided
Goodridge fittings, various, most are still wrapped
Fuel pump in-tank, new
Fuel pump external
Roll over vent for fuel tank
Fuel cap filler, race and classic
Fuel regulator for ITB's, new
Oil cooler and hoses, new
Bonnet pins, new
Air duct hoses, new
Silicone hoses and bends, most new
Weber jets and tubes, large collection
cheers!
[Edited on 2/2/16 by ephemera]
r1_pete
posted on 2/2/16 at 01:38 PM Reply With Quote
Hive you a little more info on the fuel pressure regulator? make model will do.
Cheers.
Pete.
ephemera
posted on 2/2/16 at 01:43 PM Reply With Quote
Hi Pete, Thank you for your reply. It is a KMS 4.0 bar regulator (Kronenburg Management Systems, see http://kms.vankronenburg.nl/products/fuel-system/fuel-pressure-regulator/). Red anodized body, brand new still wrapped. All fittings included.
CNHSS1
posted on 2/2/16 at 01:49 PM Reply With Quote
length, spring diameter, and spec of konis please
ephemera
posted on 2/2/16 at 02:14 PM Reply With Quote
Hi, here the requested specs of Koni:
Springs are 160 mm unsprung length, 3" diameter, fitted with the correct nylon upper and lower bushes to fit the Koni's. There is 100 written on the springs, so presumably that's the spring rate.
The Koni's are in original box, 2812 series, see http://www.koniracing.com/2812mk2.cfm
294 mm length from eye to eye. Code on box: 2812 958 233.
r1_pete
posted on 2/2/16 at 02:27 PM Reply With Quote
Thanks, it looks designed for twin fuel rails, I only have a single rail feeding 6 injectors.
Cheers.
Pete.
CNHSS1
posted on 2/2/16 at 03:09 PM Reply With Quote
price for the shocks please?
rgds
CNH
GavMax
posted on 2/2/16 at 03:21 PM Reply With Quote
Hi
I'm interested in new Goodridge fittings
What do you have and how much are you after?
Gavin
Dave Bailey
posted on 2/2/16 at 03:39 PM Reply With Quote
price for the canards please...
GavMax
posted on 2/2/16 at 03:55 PM Reply With Quote
Oh and also the carbon airbox - please will you let me have an idea of size and price.
Gavin
samjc
posted on 2/2/16 at 04:04 PM Reply With Quote
Goodridge fittings and any braided hoses pictures, details and prices please.
Also roll over vent for tank and any fillers you have.
ephemera
posted on 2/2/16 at 04:09 PM Reply With Quote
Hi all, I am trying to keep up ;-)
Canards: 10 gbp each. (6 available, first few are mint, last few have slight kerb damage)
Fuel regulator: I bought it from KMS for a single fuel rail, so the third port is simply blocked off with the correct plug.
Pair of genuine Racing Koni's incl springs and platforms, still boxed: 250 gbp
All plus P&P (Holland).
Goodridge fittings:
8 x 1136-0106
2 x 1136-0108
1 x CPL-826-06D
1 x BN506PSB
2 x 306-03-M121D
Summit fittings:
2 x SUM-220663
SUM 220633-2
4 x SUM-220648
2 x SUM-220690
SUM-220634-2
Plus a number of various bits and bobs, if you PM your email, I will send pics.
ephemera
posted on 2/2/16 at 04:14 PM Reply With Quote
It is becoming a full time job now ;-)
Carbon airbox: backplate 385 x 150 mm. Height airbox 155 mm. Inlet diameter 75 mm. Total length incl inlet: 500 mm. I have new hoses and various air filters avaliable as well. Back plate was drilled for an MI16 race engine on ITB, 4 cyl. If you send me your email address, I can send pics.
GavMax
posted on 2/2/16 at 04:30 PM Reply With Quote
I have u2u'd you
Gavin
ephemera
posted on 2/2/16 at 04:35 PM Reply With Quote
To all who requested pics, please PM me your email address and I'll send over pics.
All PM received until now I have now replied to, thanks for all the interest!
Carbon airbox incl backplate cost: 225 gbp.
Fuel filler classic incl neck: 30 gbp
Fuel filler race incl neck: 30 gbp (new)
Rollover vent: 20 gbp (new)
First pay first serve ;-)
garybee
posted on 2/2/16 at 05:32 PM Reply With Quote
I'd be interested in a price for the driveshafts.
Gary
ephemera
posted on 2/2/16 at 05:43 PM Reply With Quote
Hi all,
Here the requested prices, can send pics if you are interested:
one as good as new diff: 275 gbp
one diff fully functional, very light wizzing noise, oil plug thread weak but correctly plugged off: 150 gbp
two driveshafts (left hand and right hand side), as good as new: together 175 gbp
ajroberts
posted on 2/2/16 at 07:44 PM Reply With Quote
What size discs are they for the supalites? diameter and width?
I wouldn't follow me I'm lost
laptoprob
posted on 2/2/16 at 11:14 PM Reply With Quote
U2U ref air box
http://www.youtube.com/watch?v=ajlF4nWJtGA
ephemera
posted on 2/2/16 at 11:36 PM Reply With Quote
Hi all,
Carbon airbox, U2U sent.
Discs: 310 x 20 mm, pair. They are separate discs that bolt on to the bells, which are included. Of cours the superlite calipers can also be mounted on other discs if you want. If you send me your email address through U2U I will send you pics. Calipers, pads, discs and bells, pair, all for 200 gbp.
cheers
obr_technology
posted on 3/2/16 at 10:29 PM Reply With Quote
Any chance of some details on the oil cooler please?
ephemera
posted on 3/2/16 at 10:39 PM Reply With Quote
Hello, info on the oil cooler as requested:
13 rows, dimensions 100mm high, 285 mm wide (without mounting lips). Four mounting lips on the sides. brand new. Comes with 8 feet of blue new hydraulic hose, dash 10.
https://www.merlinmotorsport.co.uk/p/goodridge-536-series-oil-hose-10-per-100mm-g-536-10
You will need your vehicle specific oil filter take off plate and hose fittings to make it complete.
Cooler plus 8ft hose = 25 gbp, plus P&P
If you u2u me your email address I can send you the pictures.
cheers
obr_technology
posted on 3/2/16 at 11:35 PM Reply With Quote
Thank you, will send you a message.
