Author: Subject: Nissan Skyline RB26DETT Running Gear, Engine, Parts
FlansS14
posted on 5/2/16 at 12:04 PM Reply With Quote
I purchased all these parts from a friend in the hope to build a RB26DETT powered Kit car/TVR/project. I got all excited, bought all the parts then realised I don’t have the space or time to build this (not this year anyway) so im selling the lot. If someone want to build the ultimate 4wd project for RB26dett powered car I have all the bits to get you up to 420bhp and fully running. Add a £400 control box and you can switch between 2wd and 4wd anytime you like
special price to take the lot. PM me
All Parts removed from a 1995 R33 GTR V-spec 75,000KM (spun number 6 journal bearing so will need a regrind (£180) Oversized shells are available from Nissan and Kings and ACL
All pictures in this album
http://s13.photobucket.com/user/FlansS14/library/R33%20GTR%20RB26DETT
Listed as parts but will consider bulk purchase
Cam covers – full set, just been professionally bead blasted. £220
Exhaust manifolds – Just been Bead Blasted £70
Bottom end complete. Spun number 6 so will require a grind, all the other shells are spot on. The bore have very very little wear. £250
Sump with diff £150
Apexi Power FC ECU £350
RB26DETT Compete Head with cams and pulleys £550
RB26DETT Intake manifold with throttle bodies £150
Standard Injectors 440CC £150
Set of Coilpacks £55
HKS Mushroom filters and intake pipes £70
Gearbox £550
Alternator £40
Starter Motor £40
AC Pump £40
Brembo Callipers and pads (will clean up very nice)
Plus 325mm Tarox Rotors with Billet centres (Will need new bolts, available from Tarox)
Complete brake setup £300
Brake servo and master cylinder £40
Clutch master cylinder £30
Attesa Pump (I also have the loom and ECU for this) £150
Engine loom £100
Complete car loom £80
Front Propshaft £40
Rear Propshaft £60
Front uprights/hubs £60
I also have a pair of “brand new” standard size turbos. These were build by me when I worked for Turbo Dynamics. Build using the best parts available. Even used low mileage turbine housings and had all the surfaces milled flat. The ceramic wheels were replaced with steel wheels. Perfect for 1.2bar 420bhp+ approx.. no expense spent, still in the packaging with the balance and build sheets. £650 the pair
Offers excepted, Located in Christchurch and Milton Keynes. Can deliver the heavy parts within reason (There all in my van)
[Edited on 5/2/16 by FlansS14]
Why didn't i just make it simple!
Rob Allison
posted on 9/2/16 at 12:37 PM Reply With Quote
Best off on a skyline or drift forum to shift them
