Author: Subject: 1.8 Silvertop Block - Pre-95
Tatey
posted on 8/2/16 at 06:39 PM Reply With Quote
Evening all,
I am currently looking at all options for getting my Haynes on the road. I bought a 1.8l pre-95 silvertop zetec a few years ago, which I am running on Megajolt and carbs. The head gasket has gone at some point in it's life which has meant a lot of water has been sitting in the one of the bores which has damaged the bore to the extent were it either needs a rebore, a new block or a new engine.
I want to stick with a pre-95 engine as I have everything for the zetec to run on carbs, and my car is so very close to IVA I don't want to rip out my carbed system that I haven't been able to use in anger yet to fit fuel injection and a cat to get through the stricter post-95 emissions.
So I am wondering if anyone has a pre-95 1.8l silvertop block sitting around there garage they would like shot of. Ideally I would like it to be a short engine with crank and pistons as it makes my life a bit easier, if not I will take what I can get. I've toyed with the idea of buying a new engine but complete pre-95 zetecs are like hens teeth and I don't want to chuck a load of money at one to risk it being a dud like the one I own. So my plan at the moment is to rebuild my silvertop with either a new block or some oversized pistons.
On a side note, has anyone ever bored out a 1.8l to 2.0l? This means I can then fit some standard 2.0l pistons and run it with my 1.8l head. I know some people do fit the 1.8l head to the 2.0l engine and I would guess that Ford have used the same block but bored out the 2.0l.
kingster996
posted on 8/2/16 at 07:51 PM Reply With Quote
I know it's not a 1.8 but spotted this on eBay Ford 2.0L Zetec Silver Top Engine 1993 - 2004 (Zeta)
I used to be indecisive, but now I'm not so sure
cliftyhanger
posted on 8/2/16 at 08:29 PM Reply With Quote
ssshhhhhhhh......that's on my list.....
posted on 9/2/16 at 10:46 AM Reply With Quote
Given the cost of them I'd just buy another complete motor and fit it. Doesn't seem worth removing and reworking to me.
prawnabie
posted on 9/2/16 at 10:52 AM Reply With Quote
It may well be the height of the block that is different aswell, not just the bore size.
big_wasa
posted on 9/2/16 at 10:57 AM Reply With Quote
Be aware that a crate motor is unlikely to have an engine number and a rebore to your motor won't be cheap.
750mc
posted on 10/2/16 at 08:19 PM Reply With Quote
Sent you a pm
