| posted on 14/2/16 at 04:27 PM |
Diff: LSD v ATB
So, I have a 7 with a live axle and a Tran-x plated diff.
Not sure I can live with the noise though. Fine when cold, but the minute the diff heats up, then it clanks and clunks when leaving junctions and
turning slow tight corners.
I'm also not that fussed for the plates being serviceable parts... which brings me on to the 'fit and forget' Quaife ATB option.
Thing is, I spoke with the guy who built my axle (very well respected, but I'm not going to name names) and he says that the ATB is pretty much
pointless on a RWD lightweight. I can't ignore his advice - he'll have forgotten more about this than I'll ever know, but why then
do the RGB boys run them... and why do Quaife market them for RWD cars if they aren't much cut.
Over to you LCB Massiv!
It's Evolution Baby!
plutos3
| posted on 14/2/16 at 04:50 PM |
cold it be that it needs setting up for your car, If it was originally for a tin top which would be heavier it would perhaps be the problem.
twybrow
| posted on 14/2/16 at 05:11 PM |
I have a live axle and my car started life with an open diff. It acted like traction control as if you pushed on too hard, it spun up the inside rear
rather than spinning the car. I swapped to an ATB and it transformed the car. It suddenly felt like a rwd, all pointy and adjustable. You can use the
rear steer to far greater effect than without and it is quite capable of silly drifts/donuts if you wish. I have not tried a Tranx, but I can report
I really like the ATB!
minitici
| posted on 14/2/16 at 05:30 PM |
I would go for a Quaife ATB for road use any day.
The only people who complain about them in RWD are from cars with poorly set up rear suspension which lift inner wheels on corners and loose
traction.
Or from nutters with 300+ BHP who would never get enough traction regardless of the differential.
adithorp
| posted on 14/2/16 at 05:54 PM |
Got an ATB in my Fury. Works a treat. Never know it's there until you need it and then it works well.
No idea how it compares to a plate diff in the same sort of car (light) It is less intrusive under normal driving conditions in the Fury than plate
diffs I've experienced in some other (heavier) cars I've driven... They were other peoples (customers) cars though, so I can't
comment on how they were nearer the limit. Why did they say they wouldn't have one?
http://jpsc.org.uk/forum/
jeffw
| posted on 14/2/16 at 08:15 PM |
I use a ATB in the Phoenix, it has been in the car for several years. Certainly a good bit of kit.
snapper
| posted on 14/2/16 at 08:53 PM |
The only thing I would add I have recently gone from an open to an ATB (and I caveat that some other suspensions mods were also done) is that from a
very understeery 7 to one that feels initially very loose then oversteer ( very very briefly) then grabs well and grips.
It's more a confidence thing, the more I push the better it feels.
I have a friend who is well respected in a major car manufacturer, he says LSD on the road usually promotes understeer, I haven't pushed enough
to find that out yet
Earn a lot of waffle but ATB works for me
I eat to survive
I drink to forget
Wadders
| posted on 14/2/16 at 09:11 PM |
I swapped from a ford Viscous unit to a Quaife ATB, difference was astonishing, works very well in a BEC, very predictable on track. I've heard
plate diffs are better, but I couldn't be arsed with setting them up and extra maintenance. No noise or any foibles to speak of with the Quaife
it just does the job.
phelpsa
| posted on 14/2/16 at 09:32 PM |
Are you sure that the diff has the correct oil in it? Might be worth a try changing it to make sure before ruling the plate diff out completely.
Brian R
| posted on 14/2/16 at 09:44 PM |
Four locosts now in our Isle of Wight gang have now fitted Quaife atb diffs. They seem to work very well and the drivers love them.
This is a 750 mc 1300 racecar fitted with one for a mini drift comp we held at our local car club.
https://m.youtube.com/watch?v=zMry-Hogdtg
colin99999
| posted on 15/2/16 at 12:09 AM |
There's an ATB as standard in the back of my Ginetta G20 ex-race now track day car. Can't imagine they would go to the trouble/expense of
fitting them if they were no good as the car is all about value racing. Granted it's not the lightest car out there mind.
Most folks are about as happy as they make up their minds to be...
beaver34
| posted on 15/2/16 at 08:24 AM |
i run a plate in the rear of my car like you its noisy as hell, more so as your sat on the rear of the car i think
i can put up with the noise and it makes the car grip like hell so its doing its job as far as i can see, mine is a cruiser though so do see where
your coming from with the noise thing
Doctor Derek Doctors
| posted on 15/2/16 at 09:46 AM |
I had a Quaife ATB in my sprint Locost, wouldn't bother with anything else now. It just worked perfectly and the only maintenance required was
an oil change every so often.
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
Benzo
| posted on 15/2/16 at 10:50 AM |
As much as the plates are serviceable parts they are not dear to buy and will probably last the
Lifetime of your ownership.
| posted on 15/2/16 at 12:20 PM |
Thanks guys.
The diff was spec'd for the car and it handles beautifully. Is just that the noise at slow speed is almost spoiling an otherwise perfect driving
experience!
jeffw
| posted on 15/2/16 at 01:20 PM |
Get an ATB in the axle
peter030371
| posted on 15/2/16 at 01:34 PM |
What he said
Oddified
| posted on 15/2/16 at 03:45 PM |
I have plate diff in my car, the only time noise was a big issue was when i used the wrong oil in the axle.
Ian
Benzo
| posted on 15/2/16 at 03:48 PM |
My TranX has never been nosey at all either
Benzo
| posted on 15/2/16 at 03:49 PM |
Ian
Glad that ZF worked out for you in the end.
mackei23b
| posted on 15/2/16 at 07:59 PM |
I've got a Titan plate diff and it clunks and bangs.... That's with the correct preload and ramp angles, though I know others are not as
noisy as mine.
I've also had an AP suretrack, similar to the Atb and that was quite....
| posted on 16/2/16 at 01:31 PM |
Think I'll swap over to a ATB. Should get decent money back on the Tran-x.
Does anyone have any suggestions for diff guru's in Scotland who could do the needful (I can fit it, but not a chance in hell that I could set
it up properly!).
jeffw
| posted on 16/2/16 at 01:57 PM |
Road and Race in Sevenoaks
Fostek near Newcastle?
sdh2903
| posted on 16/2/16 at 01:58 PM |
I've used alpine transmissions in Hamilton a couple of times for diffs. The guy (I forget his name) was incredibly knowledgeable and had done a
lot with quaife atbs. He wasn't too bad on price either.
Oddified
| posted on 16/2/16 at 02:12 PM |
I'm not so sure that Fostek are still going
Ian
