Author: Subject: Alloy t piece
Danozeman
posted on 3/3/16 at 12:06 PM Reply With Quote
Alloy t piece
Im after one of these with 2 pipes one. does any one know where I can get one? 32mm wih 2 18mm or 16mm pipes.
pipe
pipe
Dan
pewe
posted on 3/3/16 at 12:34 PM Reply With Quote
Car Builder Solutions offer a 32mm with a tappable T if that helps?
linky
Cheers, Pewe10
posted on 3/3/16 at 02:38 PM Reply With Quote
Rover used a 32 -16-32 hard plastic Tee on the 75/ZT bottom rad hose.
ash_hammond
posted on 3/3/16 at 02:42 PM Reply With Quote
ASH Hoses.
http://www.autosiliconehoses.com/
.: www.mac1motorsports.co.uk | www.m1moc.com :.
mcerd1
posted on 3/3/16 at 03:05 PM Reply With Quote
do you mean 32mm strait through with 2 separate 18/16mm outlets ?
You could get one with a single tee - then a second tee at the smaller diameter
or you could try and find some of these the right size:
and fit them to something like this:
http://www.carbuildersolutions.com/uk/in-line-temp-sender-housingair-bleeddrain-32mm
posted on 3/3/16 at 07:37 PM Reply With Quote
I dont believe what you are looking for alloy t-piece with two outlets exists off the shelf.
Option is use two t pieces or make one, either from scratch or from an existing t piece.
Danozeman
posted on 3/3/16 at 09:44 PM Reply With Quote
That's what im finding 02GF74. Tiger list one with 2 outlets but don't stock it any more.
My problem is I have a zetec and I need to put 2 pipes into the bottom hose. What have others used?
Dan
HowardB
posted on 3/3/16 at 10:18 PM Reply With Quote
Use the original pump outlet hose (Mondeo). It has a T, then T again from that. Hope that helps
Howard
wombat
posted on 3/3/16 at 11:09 PM Reply With Quote
Pepperperformanceccose on eBay offer individual T with both 16mm and 19mm outlets.
I have asked them to quote for a one piece solution.
PM sent
