Author: Subject: Do you have a BMW 5 or 6 series? Quick q
posted on 12/3/16 at 05:09 PM Reply With Quote
I'm locked out of my 2004 645, again. Battery is flat, drivers door lock broken, boot lock is for a different key.
So I need to get a jump lead on it. 2 ideas are find the starter, which is not easy, the other is to smash the kidney grill and unbolt the bonnet catch. If you have a 6 series, could you possibly look and see if this is likely to work?!
Cheers!
Slimy38
posted on 12/3/16 at 05:34 PM Reply With Quote
Just a theory, but could you charge the battery from the boot light? Or if you're lucky, do you have an accessory socket in the boot?
posted on 12/3/16 at 05:53 PM Reply With Quote
I can't get into the boot either sadly - that's where the battery is anyway!
Looking at it closer, the grill isn't an option.
It's a bleeping nightmare. Damned if I'm breaking the window again.
theconrodkid
posted on 12/3/16 at 06:22 PM Reply With Quote
i seem to remember someone poping out a number plate or sidelight and putting some live into that
who cares who wins
pass the pork pies
View User's Profile E-Mail User View All Posts By User U2U Member   theconrodkid 's Aim   theconrodkid 's Yahoo
posted on 12/3/16 at 06:28 PM Reply With Quote
Would that work? I'd have thought it needed to be a permanent live to activate the key receiver.
Hodor
posted on 12/3/16 at 06:36 PM Reply With Quote
Can't help feeling we are aiding and abetting a TWOC
theconrodkid
posted on 12/3/16 at 06:48 PM Reply With Quote
what i was told,sidelights would be on the permanate live curcuit so worth a try ?.
who cares who wins
pass the pork pies
gremlin1234
posted on 12/3/16 at 07:44 PM Reply With Quote
what i was told,sidelights would be on the permanent live circuit so worth a try ?.
they wouldn't be, but the horn circuit may be, and its usually switched negative.
ps I know of one bmw where the battery wasn't charging, the engine stopped on the m25, he managed to get to the hard shoulder, but couldn't get out the car (all electric locks and windows)...
fortunately he had a mobile, and I had a spare key (and battery!) 20 mins later all OK
edit (but he did say bring a fire axe! )
edit: else if you do manage to open the bonnet, just energise the big wire from the alternator.
[Edited on 12/3/16 by gremlin1234]
gregs
posted on 12/3/16 at 08:00 PM Reply With Quote
Reckon you need to find the starter then....
twybrow
posted on 12/3/16 at 08:46 PM Reply With Quote
Can you jack up the front and get in at the starter or alternator by either removing the undertray or a wheel?
JC
posted on 12/3/16 at 09:40 PM Reply With Quote
On my 1 series, removing the front bumper lets you get to the bonnet catch........might help?
posted on 12/3/16 at 09:51 PM Reply With Quote
Starter, why, its not permanent live, one part of solenoid would be.
If battery in back, then cables run from rear to engine bay. If you can see positive cable then a tiny needle or pin pushed through the insulation will make contact, trickle charge it.
Can you call aa who got special tools to open doors, less hassle and maybe cheaper than window smashing.
... to avoid same situation in future, run wire from battery to underside, tape up the other end or fit asocket into which a charger can be connected.
[Edited on 13/3/16 by 02GF74]
gremlin1234
posted on 12/3/16 at 10:04 PM Reply With Quote
for the boot (US readers 'trunk' ) its not unknown to make a hole behind the no. plate. (again for US readers - license plate)
posted on 13/3/16 at 02:24 AM Reply With Quote
What makes it more depressing is that there's a trickle charger connected in the boot, but my pal turned it off! It's a nightmare but I think I have to keep digging for the starter. Its parked on a driveway that is just 2 rows of flags withgrass in the middle , on a slope. I can't get axle stands under it properly, I've had 2 under trays off, next is the subframe, and can't even see the starter yet!
posted on 13/3/16 at 05:37 AM Reply With Quote
Several videos come up after typing "how to open door to bmw 625" into google.
Any use?
ian locostzx9rc2
posted on 13/3/16 at 07:38 AM Reply With Quote
Once you have got in the car it maybe worth fixing the locks and other problems ?
jossey
posted on 13/3/16 at 01:50 PM Reply With Quote
If it's an e60 a guy in the AA opened my boot with a thin bar when mine had issues
David Johnson
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger
posted on 13/3/16 at 02:12 PM Reply With Quote
Cheers for the pointers guys. I'm not in the aa but that's one idea.
jossey
posted on 13/3/16 at 02:14 PM Reply With Quote
im sure any recovery company can do it. The starter is accessable from underneath though if you take off the engine cover.
Good luck mate.
DJ
David Johnson
owelly
posted on 13/3/16 at 04:39 PM Reply With Quote
Fit a 12S socket (if you haven't already got one fitted?!) and wire it direct to the battery (iirc pin 4 should be anyway). Then if it ever occurs again, use a 12S plug to charge the battery.....
[Edited on 13/3/16 by owelly]
http://www.ppcmag.co.uk
posted on 15/3/16 at 10:56 AM Reply With Quote
Good luck mate.
DJ
Do you know where the starter is exactly? I've got the 2 plastic covers off and the reinforcement plate too, and I can't even see a starter!
