Author: Subject: Mazda Column And PATS
the_big_1
posted on 30/4/16 at 06:07 PM Reply With Quote
Hi Guys,
I am planning on using a MX5 steering column with my Zetec engine which will use PATS.
Has anyone done this etc?
Cheers!
snowy2
posted on 1/5/16 at 05:10 AM Reply With Quote
the zetec PATS sensor is just a sensor ring that fits round the ignition switch.....it probably only needs to be near the key so fitting it close to where the key goes would likely do.
i cannot imagine that fitting it to a mazda column will give any issues.
sometimes you are the pigeon, most of the time the statue.
the_big_1
posted on 1/5/16 at 09:58 AM Reply With Quote
Hi ya,
I was thinking more about how to use the ky with the lock etc. The Mazda column wont fit the Mondeo barrel etc?
If not, how can I use the Mondeo key etc?
Many Thanks!
DW100
posted on 1/5/16 at 10:10 AM Reply With Quote
Ok, so on the Mondeo key is a red or blue dot, dig this out and a small plastic or glass bead will fall out. This is the bit that the pats needs to see.
Put the PATS ring round the Mazda steering lock and find a way to put the bead in the Mazda key and Bob's your Uncle.
the_big_1
posted on 1/5/16 at 10:14 AM Reply With Quote
Hi ya.
Perfect!!!! Sounds easy enough.
Top guys!!!
Carl
