Author: Subject: Which fuel pump do I need
Shooter63
posted on 9/5/16 at 08:59 PM Reply With Quote
The high pressure fuel pump on the car has started making a noise and no doubt is on the way out, what is a good one to fit? At the moment it feeds jenveys/2.0 zetec, but with future plans for around 280bhp, so it would need to be capable of that.
Shooter
Ben_Copeland
posted on 10/5/16 at 05:57 AM Reply With Quote
Bosch 044 will future proof your needs
Ben
Locost Map on Google Maps
Enter Your Details Here
dave_424
posted on 10/5/16 at 09:59 AM Reply With Quote
Walbro 255 would also suit, and can be fitted in-tank, or you can get an inline one
Shooter63
posted on 12/5/16 at 05:08 PM Reply With Quote
Thanks for the answers, but after a closer inspection and a real good listen ( I'm a bit deaf) I think it is the lift pump near the tank that's clattering away, so the same question, what pump do you guys recommend?
Shooter
Ben_Copeland
posted on 12/5/16 at 05:12 PM Reply With Quote
I don't have one. I just mounted the pump same level as bottom of the tank
Ben
