<<  1    2  >>
Author: Subject: Tachometer issues.... I cannot make it work :(
mark chandler
posted on 10/5/16 at 02:26 PM Reply With Quote
I purchased one these
12000RPM LCD Digital Odometer Speedometer Tachometer F1 2 4 Cylinders Motorcycle
And very nice it looks as well but connecting the tachometer pickup as follows:
Connect to the CDI output... Zilch
Connect to the coil packs .... Zilch
Connect to the injectors ..... Zilch
Wrap the feed wire around an HT lead a dozen times, it shows the idle speed but Rev the engine and it creeps up to around 2000rpm but does not go above this, I have tried less turns, around 4 and it does not sense anything.
Connect to the inductive pickup for the CDI unit and it shows 6000rmp at idle and responds immediately if you Rev the engine.
I have tried adding a 10k resistor in line and included a Zener diode when looking at the usual sources .... Zilch everything is the same as above.
Emailing China has not helped, however I did get them to send me a second one on the basis that mine is faulty but they both behave in the same way so I now have a pair.
Anyone got any ideas on how to get these to work?
There is a menu, only allows you to switch between 2 & 4 cylinders, set tyre diameter and fuel sensor sensitivity.
posted on 10/5/16 at 02:35 PM Reply With Quote
I bought a big tablet from China and its now a shiny table top....
This made me chuckle
Note:
The pointer offset does not affect the measurement accuracy, you can put the pointer to the in place. Please buy cautiously.
mark chandler
posted on 10/5/16 at 02:50 PM Reply With Quote
I do not know what that bit means, I was expecting it to have a manual red line pointer but it is just a sealed unit so nothing to twiddle externally as such.
I,m sure if I can get the right feed to it then away it will go, dumped the bike clocks as I wanted the adjustable speedo...
It looks like I have swapped a working tachometer for a working speedo.
With wire wrapped around an HT lead has anyone got any ideas of the voltage that is being pushed into the tachometer, is it just that 12v on the CDI unit is not enough?
Although I expect the voltage on the inductive pickup must be pretty low...
[Edited on 10/5/16 by mark chandler]
posted on 10/5/16 at 03:18 PM Reply With Quote
What is the coil arangmement is it wasted spark ie. one double ended coil supplies two cylinders? If so try wrapping the wire round athe plug lead on the opposite side of the coil.
With wasted spark one lead gets a positive spark the other a negative.
mark chandler
posted on 10/5/16 at 03:19 PM Reply With Quote
That's interesting, I did not know that just assumed that both coils would cause a spark positive to negative.
It's wasted spark so I will try the in a minute
Also how many turns, is there an optimum number?
gremlin1234
posted on 10/5/16 at 03:31 PM Reply With Quote
this advert for one
http://www.banggood.com/12000-RMP-LCD-Digital-Speedometer-Odometer-Motorcycle-1-4-Cylinders-p-972677.html
has quite a lot of info.
especially looking at the questions/answers
mark chandler
posted on 10/5/16 at 04:19 PM Reply With Quote
It looks like someone else has the same problem then with RPM and it will not work off the coil pack wires, I think the CDI until switches to earth which could be the problem on the coil packs which is the same as the injectors.
Ben_Copeland
posted on 10/5/16 at 04:41 PM Reply With Quote
My rev counter used to come off the wasted spark. You connect it to both signals with a diode between to stop them shorting out.
Mine comes from ecu now but it worked ok from coils
[Edited on 10/5/16 by Ben_Copeland]
Ben
Locost Map on Google Maps
Enter Your Details Here
Ben_Copeland
posted on 10/5/16 at 04:50 PM Reply With Quote
Ben
mark chandler
posted on 10/5/16 at 05:42 PM Reply With Quote
I,ve done the Zener diode, albeit off just one coil pack... Nada
I have now wrapped the wire around the second coil pack lead, flat line on this one as well ...
It's clear that a nice 12v signal (which should be perfect for most tachometers is not going to work on these ones, very annoying.
weird that it can work off the CDI input, I will tap into the alternator yellow wires tomorrow and see if that gets me an approximation of RPM.
posted on 10/5/16 at 06:55 PM Reply With Quote
Normally on all 2 wire coils the tacho is triggered on the negative side of the coil, the positive side should be near constant battery voltage no signal for the tacho to work off.
[Edited on 10/5/16 by britishtrident]
mark chandler
posted on 10/5/16 at 07:42 PM Reply With Quote
I have tried both sides, still no good
twybrow
posted on 10/5/16 at 07:46 PM Reply With Quote
Try a 1 M.ohm resistor. I had the same issue with my Koso, and no amount of changing the source or use of a dropdown resistor worked. Adding a 1 M.ohm resistor has stabilised it, so no more bouncing tachometer (connected on the signal wire from the coil on plug).
mark chandler
posted on 10/5/16 at 09:10 PM Reply With Quote
1M.
I have wondered about dropping the voltage down incase this is the problem, it's not a jumping tachometer, nothing at all on the main sources.
gremlin1234
posted on 11/5/16 at 11:36 AM Reply With Quote
would that be a 1M pull up resistor?
twybrow
posted on 11/5/16 at 12:17 PM Reply With Quote
No, inline with the signal. I backed it up with a 10k.ohm pull down, but the inline made all the difference.
gremlin1234
posted on 11/5/16 at 07:02 PM Reply With Quote
ok, I can see how that would work too ;-)
mark chandler
posted on 11/5/16 at 08:15 PM Reply With Quote
So you took tachometer lead to earth via a 10k resistor and collected the signal from the coil pack with a 1m resistor?
So have effectively dropped the input from 13.4v down to 0.134v
gremlin1234
posted on 11/5/16 at 09:18 PM Reply With Quote
yep, but the 'zero volt' signal is much better defined.
certainly worth trying.
or try with both resisters at say 100K
Oddified
posted on 12/5/16 at 05:33 PM Reply With Quote
You really need to know what signal the tacho is designed for, 5v or 12 v pulses, pull up or pull down etc. Once you know that making it work would be relatively simple otherwise it's stabs in the dark.
Ian
mark chandler
posted on 12/5/16 at 07:15 PM Reply With Quote
Unfortunately there is very little info on these, you only know how to wire it by googling as they come with zero instructions
Lots of sellers on eBay, some include the wiring instructions with the advert, it's a real shame as they do look ideal.
Oddified
posted on 12/5/16 at 08:28 PM Reply With Quote
Had a quick look, and the key part of interest is;-
Engine rotate speed comes from the ignition signal. The sensor wire is normally contacted with the positive side of the magnetor or directly wired on the rectifier.
I suspect you'll need a +/- signal and you'll need to do a bit of jiggery pokery with a resistor/capacitor to get your rpm pulse to swing both + and -.
Ian
mark chandler
posted on 13/5/16 at 06:22 AM Reply With Quote
Thanks Ian, that does confirm why it works off the CDI input.
Have you any idea what I need to make the CDI square wave output pulsed DC into an A/C signal.
Googling is not helping me to get from pulsed DC to AC with something very simply, my grasp of electronics is limited
[Edited on 13/5/16 by mark chandler]
Oddified
posted on 13/5/16 at 08:06 AM Reply With Quote
Assuming there is some input resistance to gnd on the tacho input, connect a cap in series in the wire from the tacho to where ever you know you have a nice rpm signal. Without knowing the input resistance of the tacho i'd try 0.1uF, 1uF and 10uF (if using electrolytics, neg leg to the tacho).
That should do it, if not you might also need to add a resistor between the gnd and tacho input (a cap/resistor combo that normally works is 10uf and 1k5 resistor).
Ian
mark chandler
posted on 13/5/16 at 12:12 PM Reply With Quote
Thanks Ian, I will try a later on and report back.
<<  1    2  >>
