nick9one1
| posted on 28/5/16 at 09:34 AM |
mitre saw to metal chop saw
I've seen a few videos of metal chop saws recently and they look far better than my current hacksaw/angle grinder combo.
I have a makita mitre saw (LS1040). would there be any harm in putting a metal dick in this?
From what I can tell the whole thing is metal, so the grindings shouldn't melt anything!
The wood blade is 255mm, and the closest I can find in discs is 240.
Makita Angle Grinder Cutting Disc for Metal 230mm x 3mm x 22.2mm Bore
or an expensive option..
DART 136mm - 355mm Professional Silver PMC Metal TCT Cutting Circular Saw Blades
[Edited on 28/5/16 by nick9one1]
emwmarine
| posted on 28/5/16 at 10:02 AM |
It's not a good idea putting a dick in a saw.
Building a Dax Rush.
daniel mason
| posted on 28/5/16 at 10:12 AM |
  I had to resist as well!
blakep82
| posted on 28/5/16 at 10:16 AM |
Maybe he got a metal dick as a prosthetic, because he put his normal one in a chop saw?
Anyway! Why not go for one of the evolution rage extreme saws?
________________________
ALLAN 14
| posted on 28/5/16 at 10:50 AM |
Hi.
You can use your saw with either type of blade as long as the speed of the saw is within the limits set for each type of blade.
The blades designed for metal cutting on a chop saw have a blank type of tooth to prevent jamming when cutting thin tube or sheet.
If you match the speed RPM of your saw to the requiered peripheral speed Feet/min or Mtrs/min,(rpm X 3.142 X Dia = circumference and observe all the
safety requirments, (metal fragments are very hot and are a bugger to get off when hot) you should be OK, Best rule of thumb is hold saw firmly and
proceed slowly not forcing the saw as this will only overheat and wear out quickly.
Just work safe and be happy
Allan
nick9one1
| posted on 28/5/16 at 12:02 PM |
hahaha - I really should read what I've written before posting!
corrado vr6
| posted on 28/5/16 at 03:59 PM |
I had the same idea as you, but then looked on eBay and picked up a second hand metal chop saw for the same price as a blade to put in my wood chop
saw, so I never bothered in the end. Could be worth a look on eBay to see what could be picked up cheap that's designed for the job
http://r1indy7.wordpress.com/
nick9one1
| posted on 28/5/16 at 05:37 PM |
good call, thanks!
Bluemoon
| posted on 28/5/16 at 07:37 PM |
From the sounds of it cutting metal with the correct blade will work but the particles of metal/disk are abrasive and will slowly kill a woodworking
mitre tool.. Also plastic parts may melt If using an abrasive disk.. So as a one off might be o.k but for frequent use look at other options..
