Author: Subject: EXT-RGB1 into BEC build. Anyone have experience or something similar ?
bennjamin
posted on 10/6/16 at 01:48 AM Reply With Quote
Hey team
I am building a BEC , using a small classic car chassis and body and are currently researching a reverse option.
So far , I have found many options but the latest bit of kit is a EXT-RGB1 from
http://www.extremeengines.com/cgi-bin/trolleyed_public.cgi?action=showprod_EXTRGB1
Seems strong , well built and well priced ( about £830 landed to me here in Oz)
Just wondering if anyone has any experience with this "rotation flip" style geared
down box ?
Or - any other alternatives apart from quaife or other super exxy bits ?
Thanks again Ben
motorcycle_mayhem
posted on 10/6/16 at 10:30 AM Reply With Quote
I have NO experience of the Extreme Engines unit.
I do have experience of the Quaife and Westfield units, neither of which will survive a Hayabusa/GSXR1000 Westfield on slicks. Of the two, the Quaife survived the longest, but required a breather/header tank to keep the oil in it. The Westfield one, well I had two, failed after a few hundred yards. If it's a road car you're preparing, then the situation is quite different, but again, I found the Quaife more reliable, but either were good.
I would urge you to go electric, I really would.
ArthurR
posted on 10/6/16 at 11:58 AM Reply With Quote
or use the Elite MX200 diff with inbuilt reverse
SJ
posted on 10/6/16 at 05:31 PM Reply With Quote
Aren't they about £3k?
ArthurR
posted on 10/6/16 at 05:39 PM Reply With Quote
Maybe, but you only have to buy one!
ozePhoenix
posted on 11/6/16 at 07:50 AM Reply With Quote
Looks like the Nova Racing Reverse Box
http://www.novaracing.co.uk/ReverseGearbox.html
I'm using one in my Hayabusa-engined Sylva Phoenix. No problems so far although only done about 3000k including several sprints.
Only addition I've made is a breather-tube with a non-return valve running to the back of the car from the M6 plug at top of the 'box.
I'm also down-under in Oz.
Live life on the edge - you'll take up less room that way
bennjamin
posted on 13/6/16 at 09:51 AM Reply With Quote
Thanks for the replies
The nova looks to be a different coloured version of the extreme - same price so in comparisons sake I would go for the more reputable nova.
Also have found this from elite racing transmissions.
Anyone tried ? Considerably cheaper (500 pounds) too.
