Author: Subject: Replacing rear drum brakes with motorbike disc setup - <650kg car
bennjamin
posted on 10/6/16 at 01:58 AM Reply With Quote
hey everyone
I have a small convertible which I am converting to a big motorbike engine - it comes standard drums front and rear.
Fronts will be something disc and custom - but I wonder about replacing the rears with motorbike discs for both alittle weight loss and why not.
Considering the car will have 160-180hp , and less than 650kg (depending if I run a partial roll bar etc) would some bigger front bike brakes be suitable ?
If so are there some well known kits made to suit BEC type builds ? I know of a KAD to suit minis - same sort of weight so might be an option.
I continue searching and researching and will update this thread too for future reference
many thanks Ben
posted on 10/6/16 at 05:27 AM Reply With Quote
A lot depends on weight distribution, old Mini racers of roughly the same weight most of which was on the front end used to run with almost zero rear braking, but when the static weight distribution has a rearward bias then 50-50 using the same sized discs and calipers is the usual starting point.
[Edited on 10/6/16 by britishtrident]
StevieB
posted on 10/6/16 at 06:24 AM Reply With Quote
If you're thinking of using motorbike discs, I don't think they'd be up to the job on a long term basis. Most 1000cc bikes use twin discs up front, on a bike weighing a damn sight less than a car - and the discs are usually fairly big too.
Wilwood calipers are pretty light and probably offer the best solution (similarly the KAD units you've already seen). If you're running as a road car, this would be the best option.
That said, drum brakes are pretty light and if you can run minifin drums, then that's probably the best lightweight solution IMHO.
bennjamin
posted on 10/6/16 at 06:49 AM Reply With Quote
Thanks for the replies guys
The Honda comes with alloy fin type drums on the rear standard - if it's all the easier I'll measure them and keep if OK. I am trying to use the entire rear as well.
Thanks for the info !
PS I'll update with another brake question soon thanks
ian.stewart
posted on 10/6/16 at 07:08 AM Reply With Quote
http://retrorides.proboards.com/thread/119012/1967-honda-s800-f20c
Something different, Very different..............
Ugg10
posted on 10/6/16 at 07:12 AM Reply With Quote
If it is a road car then you may want to chech whether it needs a parking brake on the rear, don't know of any bike calipers that have a handbrebrake
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
posted on 10/6/16 at 12:53 PM Reply With Quote
Personally I'd be inclined to use another road cars rear disk brakes to ensure you have a suitable handbrake system.
jambojeef
posted on 10/6/16 at 04:13 PM Reply With Quote
Ref:handbrake - Some bike calipers have two sets of pistons with separate fluid connections - the Dual CBS brake systems off Honda Blackbirds, VFRs etc have them and are cheap.
Means a hydraulic or hydro-mechanical hand brake can be designed and fabbed if needs be - I like the idea a lot and looked into it a bit.
Wadders
posted on 10/6/16 at 06:27 PM Reply With Quote
Have CBR600 discs on the rear of mine, no problems to report callipers are pug 106 for the handbrake. if it had been a track only car originally, i would have used bike callipers too for the weight saving.
