matt5964
| posted on 27/6/16 at 08:16 PM |
Sierra diff clunk once now leaking
As title says I was at Bedford gt on Saturday and during the last session I got proper sideways on the second part of the Chican just before the
stright and ax I ciollected it there was a clunk/bang from the rear I lifted off the power all seemed well so I got back on power and another clunk
was heard but half the noise of the first.
Again all felt well so I got on the power gently to get to side of track, there was no noise and it drove well so I decided to continue on as to not
cause a red flag. The car drove well no noise at all and pulled well. The only thing was that it felt like the LSD part was not working(if
that's possible as when comming out of bends the inside where span up a bit, I thought the. Tyers (toyo R1R) had got over hot and loosing grip.
Back to the pits for a ferrie around and could not find anything wrong, drove the car home and all was OK agains looked and all seemed fine.
Tonight I have a look and the diff is weeping oil from the rear case housing but not loads
Any suggestions?
Luego velocity XT 2.0ltr 221.3bhp 178.9lbft
madteg
| posted on 27/6/16 at 08:41 PM |
I have had my lsd leaking out of breather pipe on track. Found out it was boiling the oil and blowing oil vapor out, now i feed it to a catch tank
300mm above the top of the diff and check every time i visit a track.( I have not had any oil in tank as yet) I put it down to the lsd plates creating
heat on a prolonged period and not designed for the abuse we put them through
Rob Allison
| posted on 28/6/16 at 02:10 PM |
You could have damaged the planet gears. They are the weak part of the diff. also the cir-clip may have poped of one of the output shafts. Its also
possible to split the main case but normally you need twice the power you have to do that.
matt5964
| posted on 28/6/16 at 05:17 PM |
Thanks guys.
Think I'm going to get road and race transmission to look at it and rebuild if possible else it's hunt for a new one, but there
don't seem to be many 7" bolt on lsd's about
