Author: Subject: modified pinto alternator bracket
Harquil1908
posted on 19/7/16 at 07:31 AM Reply With Quote
Morning all!
dont suppose anyone on here has a spare modified pinto alternator bracket kicking around?
Trial fitted the engine over the weekend and a: the alternator is rather close to the chassis and b: the steering rack doesn't fit underneath it!
Ta
posted on 19/7/16 at 08:30 AM Reply With Quote
I had the same issue when building my MK Indy - the original donor alternator fouled the chassis and steering column.
I used a smaller Nippon Denso alternator and fabricated a mounting bracket from 50x50 angle iron. Used the OEM mounting bracket to get the engine mounting pattern and the OEM belt tensioner to adjust it. Worked perfectly and only cost an hour or so to do.
[img][/img]
posted on 19/7/16 at 08:38 AM Reply With Quote
From memory the OEM Pinto alternator bracket was cast/forged and not easily modified. The alternator itself was also not readily modifiable (lots of space in a Sierra engine bay).
Harquil1908
posted on 19/7/16 at 08:41 AM Reply With Quote
thanks nick will have a look into that. yes i have the original, the big and bulky thing that it is! I've seen made up brackets like the haynes roadster ones but as i don't have any welding equipment its a bit tricky to make one up like that.
Just curious to know how other people have got round it.
posted on 19/7/16 at 09:00 AM Reply With Quote
Hack sawing 50x50 angle iron might draw a sweat in this weather, but I had the material and smaller alternator to hand.
Harquil1908
posted on 19/7/16 at 09:23 AM Reply With Quote
don't think it could get any hotter in my garage if i tried!
mcerd1
posted on 19/7/16 at 11:18 AM Reply With Quote
this is one of the 'not so locost' options:
http://www.burtonpower.com/alternator-kit-40amp-ford-sohc-pinto-altkitso.html
but as above if you can get much cheaper alternators (little 40A kubota ones were popular at one point - all these little nippon denso ones are very similar) but you's need make your own bracket or find someone to help you
[Edited on 19/7/2016 by mcerd1]
posted on 19/7/16 at 12:23 PM Reply With Quote
My Dad got me the Nippon Denso alternator and IIRC it was from a Kubota digger (he sells them). Making the mount myself followed my DIY approach to car building.
posted on 20/7/16 at 10:02 AM Reply With Quote
Any progress or photos of what you're doing?
I'm interested to see how other people solve this one
