Author: Subject: Digidash 2 Lite - Oil Temp alarm
Patten
posted on 24/7/16 at 09:56 AM Reply With Quote
Morning all,
Trying to get my head round an issue with my Digidash
I have an an Oil temp alarm set below:
The O.I.L alarm seems to display on my Digidash way before 100c (74c was the most recent)
Once the O.I.L alarm is displayed, the two buttons on the dash don't work
Is there something really stupid that I am missing here?
Chris
rdodger
posted on 24/7/16 at 10:38 AM Reply With Quote
The settings look ok. I don't have mine any more but pretty sure that's what I set mine at.
Is there a miss match with the sensor? What temp does it display before it comes on?
INDY BIRD
posted on 24/7/16 at 12:52 PM Reply With Quote
Have you tried doing it on the digi dash programe rather than by the pc? I've press the 2 buttons together to access set up menu, and pressure its in there the correct setting,
Where have you put the oil temp guage on the engine?
Unless faulty sensor, you could swap the water and oil to see if reading ok?
neilp1
posted on 24/7/16 at 07:49 PM Reply With Quote
Isn't the O.I.L alarm from the oil pressure switch??
INDY BIRD
posted on 24/7/16 at 08:47 PM Reply With Quote
You will get alarms for,
Ota oil temp alarm
Opa oil pressure alarm
[Edited on 24/7/16 by INDY BIRD]
Jamesc
posted on 25/7/16 at 06:52 AM Reply With Quote
I was going to suggest the same about the Oil Pressure, as my DD2 shows OIL when the pressure is low.
Edit: Just below the oil pressure boxes, you have checked the option for O.I.L
[Edited on 25/7/16 by Jamesc]
Adamirish
posted on 25/7/16 at 07:54 AM Reply With Quote
Is it showing o.i.l when the engine isn't running? I have mine set up the same and mine shows the same if I shut the engine off.
MK Indy 1700 Xflow
loggyboy
posted on 25/7/16 at 08:09 AM Reply With Quote
The fact the buttons stop working makes it seem like a crash. Is there a way to reset it all to default. If not speak to ETB.
Mistral Motorsport
Patten
posted on 25/7/16 at 08:39 AM Reply With Quote
Cheers for the replys
Sorry yes it has to be the Oil Pressure alarm,
I know the Digidash comes with a pressure switch which has a mechanical alarm that kicks in every now and then which is "OPA"
The "O.I.L" alarm should not kick in because its not within the criteria specified on the software settings
INDY BIRD
posted on 25/7/16 at 08:48 AM Reply With Quote
Opa the pile pressure alarm, I had this on my zx12 as the oil pressure at idle is very low, so had to set it at something like 900rpm, or on idle the alarm message Opa would come up. Is this the same issue for you?
Patten
posted on 25/7/16 at 09:01 AM Reply With Quote
Looks like the mechnical switch kicks in, My R1 5PW Oil pressure drops below the 7.5 threshold
neilp1
posted on 25/7/16 at 05:42 PM Reply With Quote
I had this on my 1st tiger and it turned out it wasn't wired properly. Also check your earth
