New Topic New Reply
Author: Subject: MK Indy front wheel toe setting
sonic
posted on 26/7/16 at 12:29 PM Reply With Quote
Hi guys
I have just changed the front track rod ends on my Indy and need to get the tracking done, can anybody give me the setting for the Toe. at the moment I think it is 0 Neutral ?
40inches
posted on 26/7/16 at 01:48 PM Reply With Quote
Around 1.5mm toe in at the wheel rim is a good starting point.
sonic
posted on 26/7/16 at 07:26 PM Reply With Quote
Hi 40inches
I have trawled the net looking for advice on this, I tried contacting MK a number of times but no answer.
The common denominator of all the info found seems to be 0 neutral toe, I am open to comment and I take on board 1.5 I may try both and see what affect it has
hkp57
posted on 27/7/16 at 08:33 AM Reply With Quote
I initially ran 0 toe on mine but after a couple of track sessions i changed to -15min toe in just to take the edge off it and its a lot more stable at speed now.
[Edited on 27/7/16 by hkp57]
Fleet
SKC Raptor R - Hayabusa
Toyota C-HR Hybrid Limited Edition
Honda VFR1200 CrossTourer
DCT
Marlin Roadster 1800
Mercedes Vito 116 Sport
Doctor Derek Doctors
posted on 27/7/16 at 01:54 PM Reply With Quote
You'll get various answers but really it will all boil down to "a little bit of toe in" ~1mm/10mins just as long as its not toe out or loads and loads of toe in.
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
carse
posted on 4/8/16 at 12:34 PM Reply With Quote
Doctor Derek,
Why not toe out? I run mine half a degree out and it definitely helps turn-in. Run with a bit of tow in on the rears to help stability if it feels wayward.
Carse
http://www.pistonheads.com/doc.asp?c=52&i=28450
AdamR20
posted on 4/8/16 at 01:24 PM Reply With Quote
Was just going to say the same thing... nowt wrong with a bit of toe out up front, makes the front end nice and lively (as it should be on a performance car!).
SJ
posted on 4/8/16 at 01:58 PM Reply With Quote
I run half a degree in on mine. Makes it nice and stable on the motorway.
posted on 4/8/16 at 03:53 PM Reply With Quote
0 to 0.25 degrees toe-in across the axle ---- easy enough to get right with a drive over Trakrite.
SJ
posted on 4/8/16 at 04:11 PM Reply With Quote
+1 for Trakrite. They work really well.
New Topic New Reply
