Author: Subject: GSXR 1000 Map
benners05
posted on 5/8/16 at 02:42 PM Reply With Quote
GSXR 1000 Map
Hi all!
I'm having issues with my car low down in the rev range. If is a bit sluggish pulling off and there is a real kick around 5000 rpm
I've got the standard ECU in and a dynojet autotune
I'm fairly sure that the fuel mixture is right as the AFR numbers look good so I'm thinking it might be to do with the ignition timing (which I can alter using the woolich racing software I bought)
Does anyone have a map or any advice?
Cheers!
Ben
