Author: Subject: Bonnet (free) and other items (on eBay)
andyps
posted on 26/9/16 at 09:23 AM Reply With Quote
I've got a bonnet I don't need and am happy to give away if anyone wants to collect it:
Also listed a few Sierra bits on eBay last night:
Differential 7.5 inch - eBay Item
Driveshafts - eBay Item
Steering column - eBay Item
I've got a few other bits including front wheel arches which I need to sell so if there is anything you need just ask.
theduck
posted on 26/9/16 at 04:56 PM Reply With Quote
What's the bonnet off? Looks an unusual shape
andyps
posted on 26/9/16 at 07:06 PM Reply With Quote
I've had it so long I can't remember what I was told it came from when I got it. It is a normal shape for a locost style car bonnet, just that it is fairly flat from storage. Easily bends to shape around a scuttle and nose cone.
andyps
posted on 27/9/16 at 11:45 PM Reply With Quote
I measured the bonnet, it is approximately 87cm long, 94 wide at the front and 123 wide at the scuttle end. Not sure what that means it will fit but if it is of use to anyone come and collect it otherwise it will probably end up at the tip.
Skirrow
posted on 29/9/16 at 02:06 PM Reply With Quote
Don't suppose you have the stalks off the column? I'm looking for the indicator/full beam/Hazard side. Labeled 87BG 13B 302 AA
andyps
posted on 29/9/16 at 02:24 PM Reply With Quote
Pretty sure I have the stalks still - will have a look later and let you know. Need to remember where they might be!
Skirrow
posted on 29/9/16 at 04:41 PM Reply With Quote
Cheers! Just pulled mine apart in an attempt to fix it and don't think I can get it back together
andyps
posted on 2/10/16 at 12:00 PM Reply With Quote
Sorry for the delay replying, just had very busy days. I've found the column stalks - they are still attached to the complete wiring loom which will be going on eBay tonight but I can pull them off that if you want. They are the sort with one stalk on the left and two on the right. Let me know if you are interested.
Skirrow
posted on 2/10/16 at 12:42 PM Reply With Quote
Hi Andy,
That would be good. Just after the stalk on the left that does the indicators/full beam and has the hazard switch on it.
Could you let me know if it's the one with the round hazard switch? Should have 87BG or 90BG at the start of the part number stamped on the back.
And let me know how much and how you want paying
Dave
andyps
posted on 2/10/16 at 01:19 PM Reply With Quote
Number on the back is D90BG13B 302AA
second line is 012694 366123 4791
It does have the round hazard lights switch on the top.
What is it worth, £10?
Skirrow
posted on 2/10/16 at 05:22 PM Reply With Quote
Cheers, that sounds like the one. Tenner is fine by me. Do you want to PM your Paypal details or something and I'll get it paid?
andyps
posted on 2/10/16 at 05:59 PM Reply With Quote
PM sent.
andyps
posted on 4/10/16 at 11:08 PM Reply With Quote
I've still got the bonnet if anyone is interested. It might have to go to the tip if no takers.
andyps
posted on 11/12/16 at 03:19 PM Reply With Quote
The bonnet is still available but really has to go very soon - I'm doing a tip run in the next week or so and will take this if no one wants it.
Also found a Sierra steering column shroud which I'm happy to give to anyone who wants it and just on the off chance that someone has a Ford DOHC engine I have all the air inlet tubing and plenum chamber cover (or whatever it is) available - also free for collection. Don't want to throw out anything that might help someone.
