Author: Subject: Tap Wrench
Minicooper
posted on 22/10/16 at 12:17 PM Reply With Quote
Tap Wrench
Does any one know where I can buy a real proper professional industrial tapping wrench the T handle type, I already have a so called professional tap wrench but it holds the tap at quite an angle and makes it tricky to get the tap at 90 degrees and all square
Shooter63
posted on 22/10/16 at 01:34 PM Reply With Quote
Cromwell will have one or someone similar. Or the great bay of flees, for an old s/h one .
Shooter
posted on 22/10/16 at 04:15 PM Reply With Quote
Car boot sales are often a good source of old but decent tools for a bargain price. It may be worth looking at tap guides, easy to make if you have a lathe
907
posted on 22/10/16 at 04:54 PM Reply With Quote
I agree.
Better a s/h M&W off eBay than a made in China.
bi22le
posted on 22/10/16 at 05:06 PM Reply With Quote
I have used taps many times in my life and never found a good wrench.
Please read my ring story:
AJC
posted on 22/10/16 at 05:27 PM Reply With Quote
Eclipse wrenches are usually ok. Getting taps square by 'eye' is often as good as anything. A good pilot hole helps.
hkp57
posted on 23/10/16 at 06:09 AM Reply With Quote
https://www.ccw-tools.com/Presto-Taps--Dies/Tap-Wrenches--Diestocks/Tap-Wrenches__c-p-0-0-2160-2165-3301.aspx
Fleet
SKC Raptor R - Hayabusa
Toyota C-HR Hybrid Limited Edition
Honda VFR1200 CrossTourer
DCT
Marlin Roadster 1800
Mercedes Vito 116 Sport
r1_pete
posted on 23/10/16 at 10:40 AM Reply With Quote
Use a guide to get the tap square..
Tap guide
Tap guide
[Edited on 23/10/16 by r1_pete]
Smoking Frog
posted on 23/10/16 at 01:23 PM Reply With Quote
A joiner's brace is a good alternative, the jaws are designed for square ended bits. I find it easier to use than a wrench, works well in confined spaces with the ratchet engaged.
