adampage
| posted on 1/11/16 at 09:57 PM |
Various - Shocks, Diffs, Box, Wheels & Tyres, Seats, Uprights, Wingstays, Prop, Shafts, etc
Hi All,
Updated - I've added a couple of other things now.
Anyone interested?
- 2 GAZ shocks & springs, 2.25" x 9", 250lb springs, brand new & never used, £240 new, for sale now £150 - 2 photos in archive
- GBS Roadster seat - brand new, never used, £90 new, now £60 - 2 photos
Sierra 7” open diff, 3.62 ratio, bolt on type – Told it was recon by seller, but can’t verify. It does turn smoothly though. £120 - 2 photos
Sierra 7” open diff, 3.62 ratio, push in type – Turns smoothly. £100 or £150 with shafts - photo
Sierra drive shafts to fit push in diff. Comes with both hub carriers and hubs. Could obviously come as a set with the diff above. £50 - photo
Sierra t9 box, believed to be the diesel which means long input shaft, some larger HD bearings, but different ratios to normal. Turns smoothly. Comes
with lever £100 - 2 photos
Sierra t9 bellhousing, the standard ford one, can go with box obviously as a set, fits most older ford engines (I believe xflow, pinto, zetec but not
new ones like sigma or duratec), comes with clutch lever arm £20 - photo
Sierra t9 prop, believed from an MK Indy or MNR, so length should be fine for similar car £75 - photo
Sierra front uprights x2, old & crusty, but believed undamaged, one could do with a bearing, the other feels smooth £25 – 2 photos
Sierra front wing stays x2 (MK I think), good condition, unbent so you can make to size, could come with uprights as a set £40 - photo
Alloys x4, black six-spoke, 7x15, ET38, I don't know the make (there are some codes/logos on the back but I don't recognise) with
virtually new Toyo Proxes T1r tyres, 2x 195/50, 2x 205/50. Wheels are generally good nick, just a few tiny little scuffs/scratches, but hardly
noticeable £300
1 double-skinned GRP seat, with rubber matting & trim around seatbelt holes, with runners. We trimmed back the outer skin right at the bottom /
back corners underneath for about an inch to le them sit further back, but it doesn’t affect the runners / strength at all. £100, 3 photos.
Any questions, let me know!
Ad
(I also have a few other things which I’ll put up soon, an RX8 box (possibly sold, awaiting confirmation from a potential buyer), and then a 138bhp
Caterham K series supersport engine, complete kit from air filter to exhaust tip, shallow sump & windage tray, engine plumbing & wiring, ECU
& keys, done 25k miles, from someone on the Lotus7Club website.)
[Edited on 3/11/16 by adampage]
cfc999
| posted on 6/11/16 at 10:49 AM |
U2U sent.
Chris
adampage
posted on 6/11/16 at 07:27 PM |
Replied, thanks!
cfc999
| posted on 6/11/16 at 09:38 PM |
U2U sent
GavMax
| posted on 6/11/16 at 10:23 PM |
U2U re the dampers
Gavin
cfc999
| posted on 6/11/16 at 11:34 PM |
Nothing come through as yet.
adampage
posted on 7/11/16 at 09:35 AM |
I think you've got it now, thanks
ianminki
| posted on 8/11/16 at 09:32 PM |
prop
ianminki
| posted on 8/11/16 at 09:34 PM |
prop
hi
can you tell me if the prop would fit a 4 speed gear box pls and what is the length . my car is a ssc stylus same chasses as fury
regards ian
adampage
| posted on 8/11/16 at 11:03 PM |
I must admit, i don't know....
I can measure it up tomorrow, length and hole centres for the bolts onto the back of the gearbox.
I'll let you know.
Adam
adampage
| posted on 9/11/16 at 07:53 PM |
Measurements
Hi
I measured up. The prop is 57cm from centre of uj to centre of uj, and 76cm overall, from the tip of the nose that slips into the gearbox to the diff
flange.
I don't know how to tell if it fits the 4spd box, but I believe it's from a type 9, so if they're the same then it should be
fine.
Hope that helps, or let me know if you need any more info.
Ad
ianminki
| posted on 9/11/16 at 10:38 PM |
prop
hi
thanks for that and I will find out if its same fitting for the type e 4 speed box and check the length is right and get back to you
regards ian
ianminki
| posted on 11/11/16 at 09:20 AM |
re prop
hi
thanks but prop is not going to fit bit 2 short
regards ian
adampage
| posted on 11/11/16 at 09:57 AM |
OK, thanks for the interest, good luck finding one!
MDR1987
| posted on 11/11/16 at 02:04 PM |
U2U sent re shocks/springs if still available, thanks
adampage
| posted on 26/11/16 at 09:07 AM |
Matt21 - u2u sent
I can send wingstays today, just check the u2u
Thanks!
Ad
