Author: Subject: R1 engine complete setup
rabbit
posted on 6/11/16 at 07:28 AM Reply With Quote
Hi will be selling complete r1 engine/ exhaust/ sprocket/ prop/ clocks/ paddle shift with cable/engine cradle in fact all parts to make it run.
it will only be available when i have found a replacement car engine package. the r1 is in a fury i recently brought lots of work done by kitcar
workshop, never finished or used that i can tell, engine needed carb float bowls cleaned and idle jets were blocked fresh fuel put through the system,
hooked up water system put anti freeze in fired up run up to temp.and adjusted tick over ran ok, been advised complete package price should be £850
based east sussex
rabbit
posted on 10/11/16 at 05:26 PM Reply With Quote
will consider offers for complete R1 set up, now found car engine replacement, R1 can be seen running before removal from the car if your quick.
rabbit
posted on 14/11/16 at 06:31 PM Reply With Quote
price drop
started to remove from car, drop the price to £650 complete package or may break into parts
rabbit
posted on 16/11/16 at 07:45 PM Reply With Quote
R1 engine
SOLD subject to collection & payment thanks for the interest to all that replied.
