<<  1    2  >>
Author: Subject: Make an engine turn the opposite way around?
Alez
posted on 8/11/16 at 08:13 AM Reply With Quote
Hey guys,
I'm wondering: is there a fundamental reason why you can't make an engine turn the opposite way around by changing its cam shaft to a custom one? (and adjusting ignition). I'm thinking that would allow one to turn a rear engined car into a mid engined car by putting its drive train reversed.
Alex
Schrodinger
posted on 8/11/16 at 08:23 AM Reply With Quote
I'm not too sure about the cams but you would need to rebuild the engine with the pistons turned as the gudgeon pin is not central. Which engine are you thinking of? Iirc in the 60's/70's it was popular with the beetle engine to turn the gearbox over so that it could be used as mid engine.
Keith
Aviemore
r1_pete
posted on 8/11/16 at 08:26 AM Reply With Quote
In the 50s some Panther single motorcycle owners had their ignition advance lever adjusted so in one extreme position they could make their engines kick back and run in reverse it was useful when hauling a sidecar, I wasn't there so haven't seen it done, just read about it.
Alez
posted on 8/11/16 at 08:30 AM Reply With Quote
Thanks, Keith.
I don't have anything in particular in mind, just wondering if it makes sense to do that and/or it's been done, but your reply makes it clear that it involves major work which makes it pointless given other options like using a front engined car drivetrain or the one you mention.
These days I'm liking the Simca 1000 Rally small saloon and sometimes I find myself thinking random things related to rear engine configuration
Alex
Alez
posted on 8/11/16 at 08:32 AM Reply With Quote
Wow, just ignition. I thought cam timing would need reversing.
posted on 8/11/16 at 08:59 AM Reply With Quote
Simca 1000 and the later fwd Chrysler engines were anti-clockwise rotation anyway.
They were very prone to camshaft wear problems.
posted on 8/11/16 at 09:03 AM Reply With Quote
Only valveless 2 strokes can run backwards without major changes.
Alez
posted on 8/11/16 at 09:09 AM Reply With Quote
Hmm why do you mention this, does it make any difference which way it rotates? Just curious.
Oh, of course 2-stroke don't have valves, that explains it
posted on 8/11/16 at 09:11 AM Reply With Quote
As above I understood IC engines were designed with rods and associated pivot points off centre to handle the explosion forces. With that in mind I'd have thought running them backwards would run mechanical risks and increase wear on cylinders and pistons.
Whilst not a transmisson man I'd imagine transmissons are designed and tested to work with certain oil capacities and movements. Running them upside down would change this dramatically and no doubt raise issues with fill/drain plugs and breathers.
What sort of project are you thinking about?
Some more guidance on what you're looking to achieve may help us suggest some transmissions for you.
Alez
posted on 8/11/16 at 09:16 AM Reply With Quote
Thanks, Nick
It's just curiosity. I'm not even a builder. I thought I had seen other solutions before, but not the one I was thinking, and I was wondering if that was because it can't be done easily (which I've now confirmed) or maybe it had been done but I wasn't aware.
Alex
Alez
posted on 8/11/16 at 09:22 AM Reply With Quote
Hmm I thought it's a typical thing to do... the G50 transaxle for example is used that way on GM V8 (small block) Ultimas and similar cars with same configuration (Lambo replicas, etc.), I seem to remember.
[Edited on 8/11/16 by Alez]
red22
posted on 8/11/16 at 09:30 AM Reply With Quote
VW Beetle gearboxes just get the diff flipped to the other side of the pinion. No inverting of gearboxes needed.
Ivan
posted on 8/11/16 at 10:50 AM Reply With Quote
It has been done to Honda engines a number of times for racing engines. No serious complications - they cut new camshafts. It's also done on American V8s for marine use where twin engines are installed.
Google it.
posted on 8/11/16 at 11:08 AM Reply With Quote
Yes I think Ultima do use an inverted Porsche G50 transmission. Porsche being Porsche I suspect their transmissions are rather well engineered and in that instance proven to work OK inverted.
There was a recent thread on using VAG transaxles for RWD cars - http://www.locostbuilders.co.uk/viewthread.php?tid=205354
VAG cars using them have the engine and transmission mounted longitudinally. My concern would be the length of the engine and transmission in this configuration for a mid-engine car. I'd have thought using a FWD engine and transmission layout in a mid-engine position would be more effective and give a shorter car overall. It would also give you more choice of donor engine and transmission too.
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 8/11/16 at 11:23 AM Reply With Quote
Lots of Villiers engines were fitted with the Cibie dynastart system which allowed the engine to start in reverse, lots of large marine engines can run either way by simply moving a lever to move the camshaft to a different set of lobes and as far as the Simca Rallyes are concerned you should check out the French hill climb (course de cote) scene and see what kind of speeds they are doing, scarely quick.....
posted on 8/11/16 at 01:20 PM Reply With Quote
You would have to rearrange the can chain tensioner to the opposite way and re engineer the oil pump to make it pump properly... Then a host of other mechanical things.
Why not just use any fwd engine and box in the back of a midi????
r1_pete
posted on 8/11/16 at 01:26 PM Reply With Quote
Probably some urban myth I've mis remembered.....
mcerd1
posted on 8/11/16 at 01:38 PM Reply With Quote
but the driveshafts come out quite close to the front:
so if you can afford the overhang to the rear its not so bad (thats the audi 4.2 V8 in the pic so hardly a compact engine)
always thought it looked quite neat in this build: linky
trialsman
posted on 8/11/16 at 02:10 PM Reply With Quote
Didn't some of the older Honda car motors run opposite rotation. I don't know the series designation but they were in older Civics. Russ
Dingz
posted on 8/11/16 at 02:54 PM Reply With Quote
Lots of Villiers engines were fitted with the Cibie dynastart system.
I had a scooter with this set up, it gave me a bit of a shock when it had started backwards and I tried to pull away!
went on and on.
jollygreengiant
posted on 8/11/16 at 03:04 PM Reply With Quote
From the purist technical side, not a good idea to run an engine the wrong rotation.
Gudgeon pin off-set would be wrong.
Little end lubrication would be aligned wrong for the piston loading.
The crankshaft would need a re-grind to allow for rotational difference (crank rotation is important for re-grind operatives, or that is what I was told in the engineering workshop).
Timing chain and timing belt tensioners would be incorrectly sited and loaded.
Just my 2p's worth at a reply after 30 seconds of viewing the question.
Alez
posted on 8/11/16 at 03:14 PM Reply With Quote
I'm most familiar with that configuration because I've been the owner of an Audi 4.2 V8 engined Ultima for a few years and it used a VAG 6-speed. Here's a pic of the engine bay:
It's a very compact installation in Ultima engine bay size terms, there was significantly more space than the average GM V8 gives. The whole thing worked really well.
I got interested in the Simca 1000 because a guy here in Madrid does hillclimbs with a 1000 Rallye 3
Alez
posted on 8/11/16 at 03:19 PM Reply With Quote
Well, definitely it seems there's PLENTY wrong with it, after all
r1_pete
posted on 8/11/16 at 03:22 PM Reply With Quote
Thinking that one through, the oil pump would run the wrong way, any white metal forced lubed bearings wouldn't last long either.
posted on 8/11/16 at 03:34 PM Reply With Quote
Thinking about the original op question I think flipping the diff would be the best way...
<<  1    2  >>
