Author: Subject: Bhp used by reverse gearbox?
limpetminer
posted on 16/11/16 at 09:10 AM Reply With Quote
How much power does a quaife reverse gearbox use on a typical 1000 cc bec? been told its 30 bhp which seems like a lot.
loggyboy
posted on 16/11/16 at 09:30 AM Reply With Quote
Would be percentage not an exact figure - ie if you put 30 bhp in it wouldnt give 0 out.
Website states its 'straight through' to minimise power loss. I suspect its a fairly minimal loss. So any major losses would only be when its in reverse.
[Edited on 16-11-16 by loggyboy]
Mistral Motorsport
AdamR20
posted on 16/11/16 at 03:05 PM Reply With Quote
A friend of mine dynoed a 6bhp loss on an R1.
loggyboy
posted on 16/11/16 at 03:38 PM Reply With Quote
What were the 2 max power figures?
Mistral Motorsport
Andy B
posted on 16/11/16 at 04:14 PM Reply With Quote
In our experience you can expect between 6 and 12 bhp depending on the condition of the box. For some strange reason the box is direct drive in reverse which makes it far smoother and more efficient when going backwards.
Regards
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Andy+B 's Aim
loggyboy
posted on 16/11/16 at 04:46 PM Reply With Quote
Regards
That contradicts there website - have they revised the design?
: https://shop.quaife.co.uk/quaife-reversing-box
Mistral Motorsport
AdamR20
posted on 16/11/16 at 05:37 PM Reply With Quote
Not certain exactly, and if that was wheels or estimated fly, but I think it was a 2007 engine that had a few tweaks so was up around 180-190bhp or so.
ReMan
posted on 16/11/16 at 07:01 PM Reply With Quote
Wow 30hp!
But even 6 sounds a lot!
Assuming the MNR is similar there's not a lot of resistance by hand. I'd expect to take some and worse so at higher revs, but 6 still seems a lot
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
View User's Profile Visit User's Homepage View All Posts By User U2U Member   ReMan 's ICQ status
loggyboy
posted on 16/11/16 at 07:59 PM Reply With Quote
Originally posted by ReMan
Wow 30hp!
Its not just about resistance, although that is the root cause, as energy can never be lost, only transfered, things like heat and noise are where the energy 'goes'.
Mistral Motorsport
posted on 17/11/16 at 10:58 AM Reply With Quote
Regards
If it was direct drive, then the output shaft would not be reversed, literally by definition. Was this maybe a case of having the wrong diff or something and requiring a reverse to get forward motion?
garyo
posted on 18/11/16 at 11:06 AM Reply With Quote
A Jap engine spinning the wrong way??
