Plunky
| posted on 26/11/16 at 04:30 PM |
F27 rear disc brake upgrade
Looking to upgrade the rear drums to Calipers/discs on my F27.
I already have a set of Sierra calipers.
Can anyone assist me in identifying which kit to buy please?
There seem to be a lot on eBay, just unclear what I actually require. A bolt on kit would be preferred.
Thanks,
Liam
Ugg10
| posted on 26/11/16 at 04:48 PM |
Have a look on eBay for either caprisport or oldphonebloke, he sells brackets for the English axle and Sierra calipers. Also oldfordautos do them. I
managed to use the Sierra discs and calipers on my Anglia with an English axle, this is a pretty standard conversion. But beware the escort, Capri and
Anglia are slightly different.
[Edited on 26/11/16 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
ragindave
| posted on 26/11/16 at 04:50 PM |
Hello Is this for an IRS F27?
Plunky
| posted on 26/11/16 at 05:02 PM |
It has a live rear axle, English or atlas (if there is any difference)
ragindave
| posted on 26/11/16 at 05:12 PM |
The IRS F27 is Sierra based I had some info for you if yours was IRS.
Ugg10
| posted on 26/11/16 at 05:39 PM |
English diff and atlas are different. Iirc English diff loads from the front, atlas has a removable rear plate.
Worth asking why you are wanting rear discs, on a light car drums are usually plenty good enough and rear discs will over brake the rear making it a
handful.
ali f27
| posted on 26/11/16 at 06:10 PM |
Hi i put willwood 4 pots on mine think they use fiesta discs would still do it again but have to say i had to gear the handbrake up to get it to mot
standard and i now have very pretty rear brakes but a crap handbrake and no better braking on the rear than i had with drums. Have a look at rally
design web site for reference Cheers Ali
ali f27
| posted on 26/11/16 at 06:13 PM |
By the way those sierra calipers will be heavier than the drum brake set up.
Plunky
| posted on 27/11/16 at 10:57 AM |
I'm totally aware of the performance implication, if I'm honest it's mainly for asthetics...
I'm not aware of it having a negative effect on performance though. With the correct use of a brake bias valve I should be able to get a decent
brake performance
Plunky
| posted on 27/11/16 at 10:59 AM |
handful.
Thanks for that bit of info. I believe I have an Atlas axle then as there is a plate on the rear
Plunky
| posted on 27/11/16 at 11:56 AM |
Would this kit work?
https://www.ebay.co.uk/itm/221204325312
