24vseven
| posted on 3/4/17 at 01:49 PM |
Mx5 propshaft
Apologies if this has been covered before but are all mx5 propshafts the same spline on the gearbox end. I need one for a hybrid prop and
there's a marked difference in price between the mk2.5 and mk3.
Thanks in advance.
Smokey mow
| posted on 3/4/17 at 03:54 PM |
Mk1 to Mk2.5 should all be the same spline as they share a common gearbox but I would expect the Mk3 to be different.
miskit
| posted on 3/4/17 at 10:45 PM |
I have a Mk 2.5 propshaft that is
a) for sale
b) available for photo's of either end if it helps (irrespective of a) obviously)
24vseven
| posted on 4/4/17 at 06:00 AM |
Thanks.
Not so much photos but if you could measure the diameter and how many splines I can compare to my box and see if we're close.
Furyous
| posted on 4/4/17 at 07:09 AM |
From memory, the Mk3 is 23 splines. Could be wrong on that, though.
Davg
| posted on 4/4/17 at 08:31 AM |
The mk2 prop fits a mk3(N7) box.
Cheers D
miskit
| posted on 4/4/17 at 11:23 PM |
OD is 35mm, ID plain 26mm, ID splines 22mm
The splines have a pattern 10 +10
HTH
pic:
[Edited on 4/4/17 by miskit]
