Author: Subject: Healtech Quick Shifter - Anybody used one
hkp57
posted on 10/4/17 at 11:36 AM Reply With Quote
I am thinking of fitting a quick shifter, anybody had experience of this one?
https://www.healtech-electronics.com/products/qse/
Fleet
SKC Raptor R - Hayabusa
Toyota C-HR Hybrid Limited Edition
Honda VFR1200 CrossTourer
DCT
Marlin Roadster 1800
Mercedes Vito 116 Sport
The Knobs
posted on 12/4/17 at 09:08 AM Reply With Quote
Has anyone got one fitted?
hkp57
posted on 15/5/17 at 07:52 AM Reply With Quote
Well I went and bought one, fitted it yesterday, took about one hour.
Truly is a plug and play, no cutting in the wiring loom, only additional connection was a ground wire, everything else plugs into the coil packs.
Download the app onto my phone, ran the setup wizard, a small adjustment to the preload on the strain gauge and we were done.
Just need the rain to stop for a road test but so far it's a 10 out of 10 for ease of install.
Fleet
DCT
ptrxly
posted on 24/5/17 at 05:23 PM Reply With Quote
Road tested the Quickshifter yet? How are shifts at low RPM?
hkp57
posted on 24/5/17 at 06:34 PM Reply With Quote
Yeah we had a good run out on the track with it and it worked well.
I set it up so it does not work below 3000rpm, every change after that was smooth long as you are on part throttle.
If you are coasting and just want to change up you need the clutch.
I had an issue when it stopped working but the nut holding the load cell had backed off a bit, drop thread lock sorted that out again.
Clip of my last run with it, excuse the noise the mic fell off its mount
An the gear indicator is next to get looked at. Think the wiring is picking up electronic noise so need to isolate it.
Fleet
DCT
ptrxly
posted on 27/5/17 at 03:26 AM Reply With Quote
Would you recommend one for street use?
hkp57
posted on 27/5/17 at 05:30 AM Reply With Quote
Yes
Fleet
DCT
Mavrik
posted on 7/8/17 at 10:20 PM Reply With Quote
Got a Healtech QSE on my '07 HRC Fireblade & it works brilliantly... Seriously considering getting another for my Carby MK IndyBlade...
My Other Rides:
HRC Limited Edition RR-7 Fireblade
350zed HR 313 Convertible
Mercedes-Benz SLK Kompressor
CosKev3
posted on 8/8/17 at 11:45 AM Reply With Quote
Do they do them for carbed engines?
As you have no ECU as such,just a CDI?
hkp57
posted on 8/8/17 at 12:33 PM Reply With Quote
Yes they do CDI units also, download user .Guide Here
There are two iQSE models. Make sure you received the correct one:
- The iQSE-1 is for bikes with TCI (Transistor Controlled Ignition). TCI is the
current technology and most bikes on the road today require the iQSE-1.
- The iQSE-2 is for bikes with CDI (Capacitor Discharge Ignition)
[Edited on 8/8/17 by hkp57]
Fleet
DCT
Mavrik
posted on 8/8/17 at 02:07 PM Reply With Quote
Yep. .. They also do the QSE for older car bed BEC 😄
My Other Rides:
The Knobs
posted on 9/8/17 at 11:40 AM Reply With Quote
So 250 all in, looks like a good buy?
