Author: Subject: lightweight battery for fireblade
andyfiggy2002
posted on 11/4/17 at 07:48 PM Reply With Quote
870grams!!! is there a catch for all this lightness?
Lithium Ion 12V Motorcycle Battery Race Car Kitcar Lightweight LIPO12C YTX12-BS
mark chandler
posted on 11/4/17 at 08:16 PM Reply With Quote
Saw these at Silverstone last year, they feel like you are picking up a plastic toy.
The chap selling them said they will crank quickly but not for a long time, I believe you get a large capacitor and lithium battery within the case hence the instant power.
If my car floods the plugs, which it can do in seconds it takes ages to start, usually have to cook the plugs and stick them in hot!
andyfiggy2002
posted on 11/4/17 at 08:28 PM Reply With Quote
So recommended or not?
posted on 11/4/17 at 08:34 PM Reply With Quote
I've got one and it fires up my st1100 just fine- mine is a different Manafacturer but looks identical in every way other than the label . The only idiosyncrasy is if it seems to be struggling (not that it ever has) the recommendation is to put the headlights on full beam for 30 seconds then try again. The current draw warms the battery giving full capacity.
posted on 11/4/17 at 08:38 PM Reply With Quote
Mine is a Magnetti Morelli. I think the stock st1100 battery is about 4.5kg so quite some saving. And the new battery is lower so less weight lower down in the car
andyfiggy2002
posted on 11/4/17 at 09:02 PM Reply With Quote
I thought my motobatt was light at 3.5kg but 870g...WOW
daniel mason
posted on 11/4/17 at 09:08 PM Reply With Quote
I use a lighter one than that on my force. And I did on the Jedi.never had an issue!
andyfiggy2002
posted on 11/4/17 at 09:14 PM Reply With Quote
Is a force/ jedi 600cc?
I assume I will need a hjtx9-fp lithium for my cbr900rr?
daniel mason
posted on 11/4/17 at 09:23 PM Reply With Quote
No,I have a AB performance cbr1000 rr in the force. The Jedi had a carbed R1
daniel mason
posted on 11/4/17 at 09:24 PM Reply With Quote
I get mine from Allan McDonald on uphillracers forum.
andyfiggy2002
posted on 11/4/17 at 09:31 PM Reply With Quote
I'm aiming for sub 400kg for my road legal megablade so if I purchase one of these & a set of force split rims that should do it
[Edited on 12/4/17 by andyfiggy2002]
daniel mason
posted on 11/4/17 at 09:42 PM Reply With Quote
You'll be pretty close depending on seat,cage and tyres id imagine, but 405 - 410 would still be very light.
Some of the hillclimbers have pretty light westfields but not 100% sure on the exact weights as I'm in a different class at events. Ours are extremely light indeed
jeffw
posted on 12/4/17 at 05:15 AM Reply With Quote
There are CEC Westfields under 400Kg.
I have the largest Lithium that Russbost does and its only issue is low ambient temp. If you try and start my car and the ambient is under 8-9 deg it struggles, you have to leave it then try again and then repeat. It will crank it at full speed once the battery is at the right temp. Apart from that all good.
Paul_Arion
posted on 12/4/17 at 05:40 AM Reply With Quote
Besides starting the car, how do these Lithium Ion batteries cope with electric reverse? I guess with the car being in use it'll help with the battery being warmer than typically it would when starting her up??
andyfiggy2002
posted on 12/4/17 at 06:20 AM Reply With Quote
apparently in cold weather if you 1st put your lights on until they go bright this will warm up the battery to!!
Also you can lay them on their side which is useful if you want less aerodynamic drag!!
tankplanker
posted on 12/4/17 at 08:08 AM Reply With Quote
How long do these type of batteries hold charge? I tend to take my Indy out over the weekend and I'm wondering if I'll need to leave it on trickle charge over the week.
daniel mason
posted on 12/4/17 at 04:12 PM Reply With Quote
My car used to sit for up to a month and just fire up straight away.
How the hell are they getting car engines westfields under 400kg? That seems lighter than the bec's
posted on 12/4/17 at 08:53 PM Reply With Quote
The only real catch is that they have far less capacity (Ah) than the lead acid battery they replace. This is not always obvious since some manufacturers like to deceive by giving out an "equivalent" lead acid rating, i.e. the capacity of a lead acid battery that would match the cranking current of their Lithium battery. In reality a bike battery for a litre bike might have a capacity of 12Ah, and the equivalent lithium iron phosphate battery might have a capacity of just 3-4Ah.
Mavrik
posted on 17/11/17 at 11:58 PM Reply With Quote
I'm running a LiFePO4 Shido on my MK Indyblade (RRX motor) & the weight saving is ridiculous!
Zero issues with it's performance.
I did also upgrade my reg/rec unit to a SHINDENGEN FH012AA MosFet with a custom heatsink fan
My Other Rides:
HRC Limited Edition RR-7 Fireblade
350zed HR 313 Convertible
Mercedes-Benz SLK Kompressor
