Author: Subject: Omex 600 - brand new
johnH20
posted on 5/5/17 at 07:16 PM Reply With Quote
Due to change ofplans I have for sale a brand new Omex 600 plus a full range of accessories. Until taking photos for Ebay the ECU had not been removed from its box let alone seen a garage! Kit includes Omex 600 ECU, Programing kit including all discs and manual, semi assembled wiring loom with enhanced wiring pack, coolant temp sensor, water temp sensor, plus Ford coil connector. This lot retails for over £750. Offered to members on here for £550 posted, before going on Ebay ( it will be more there! )
arrow-engineering
posted on 6/5/17 at 10:02 PM Reply With Quote
is the loom just the main plug with wires attached? and whats the enhanced pack consist off?
1960dave
posted on 7/5/17 at 04:49 PM Reply With Quote
ecu
Did you put it on ebay?
1960dave
posted on 7/5/17 at 08:27 PM Reply With Quote
[Edited on 8/5/17 by 1960dave]
johnH20
posted on 8/5/17 at 03:06 PM Reply With Quote
Hi arrow - engineering. Semi assembled loom is Omex speak for 'the plug with wires on it'. Individual wires are about 230 cm in length. Auxiliary wires are approx. 12 in number ( from memory ) and provide access to some secondary functions of the ECU. I have tagged the wires for my intended use with tape. You may need a different selection
johnH20
posted on 10/5/17 at 03:55 PM Reply With Quote
1960 Dave. You have PM.
