Author: Subject: Can exhaust be ridgid?
craigdiver
posted on 26/5/17 at 05:27 PM Reply With Quote
Can exhaust be ridgid or does it need some flex component?
Engine is BMW 6 cylinder and original exhaust did not have flexis but probably had play in the rubber exhaust hangers. I'm using the landrover engine mounts that seem stiff, will the engine move much under load?
[Edited on 26/5/17 by craigdiver]
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
theduck
posted on 26/5/17 at 05:37 PM Reply With Quote
Just use rubber bobbins to mount the exhaust to the car?
gremlin1234
posted on 26/5/17 at 05:52 PM Reply With Quote
engines move quite a lot, so you need some flex somewhere.
the other problem with a rigidly mounted exhaust is conducted noise.
40inches
posted on 26/5/17 at 06:01 PM Reply With Quote
This is true. I have my silencers rubber mounted, but the manifold/down pipe joint keeps leaking, I am fitting flexi joints, hopefully that will cure it.
Nickp
posted on 26/5/17 at 07:13 PM Reply With Quote
My BMW 6 is on Landy mounts too but I've also fitted a Mini engine steady. The exhaust has no flexi and the silencer is sat on a single poly bobbin. Too early to say if this is gonna last without an issue.
ianhurley20
posted on 26/5/17 at 07:18 PM Reply With Quote
My engine is on MX5 engine mounts and the end of the exhaust is on a rubber/metal silencer fixing (can't remember what I pinched it from) it has two studs each side of the rubber and it works fine :-)
SPYDER
posted on 26/5/17 at 07:21 PM Reply With Quote
I'd just do this. The side-exit exhaust in my car is essentially rigid, end to end. Only the silencer is rubber mounted.
My mates Westfield was the same.
If your mounts are stiff the engine might not move much at all.
craigdiver
posted on 26/5/17 at 07:32 PM Reply With Quote
Hi Nick, your not sounding too confident ;-), if you made your exhaust again, would you have fitted flexis?
Craig
Nickp
posted on 26/5/17 at 07:59 PM Reply With Quote
Craig
No
rodgling
posted on 26/5/17 at 08:25 PM Reply With Quote
Mine is on Land Rover mounts, the exhaust is sat on rubber robbins, no flexi section - it's been fine for 6 years. In that time I've had to replace a mount and a bobbin, I think, but the exhaust is completely fine.
[Edited on 26/5/17 by rodgling]
benchmark51
posted on 26/5/17 at 08:29 PM Reply With Quote
My Pinto manifold was over the rail type, 4 into 1 and was rigid to the silencer mount. The mount was a big cotton reel type. I found that the silencer developed an internal rattle that quietened as it warmed up and I suspected the rigidity of the exhaust set up. I put in a short flexy pipe between the manifold exit and silencer and was surprised at how much the engine was now moving. I think including a flexy section is a good idea.
craigdiver
posted on 26/5/17 at 09:47 PM Reply With Quote
Good advice thanks, don't think having the exhaust supporting the engine sounds like a good idea.
