HappyFather
| posted on 25/6/17 at 12:36 AM |
Swapping diff internals between tripod and lobro
Hi people,
I've been considering a diff swap on my car. I currently have a 7,5" 3.62 lobro.
I'm looking to get a 3.14 in but I can only seem to find 7" 3.14 tripod.
I've checked with Aries and I can use a 7" on my car. But I want to keep lobro.
If I buy a 7" 3.14 tripod and a 7" any-ratio lobro, can I change the internals of the tripod to the lobro case?
And is it something that can be done by a monkey with a spanner (me) or should I get a proper mechanic to do the job?
Thank you for the answers! Cheers,
HappyFather
P.S. - I know I can't get a 7" 3.14 internals and put them on a 7,5" case, unfortunately...
minibull
| posted on 25/6/17 at 02:01 AM |
I'm fairly sure (i.e. not 100% certain) that internals don't swap over. Usual way to interchange between Tripode and Lobro diffs is swap
ends of drive shafts over at CV joint. Problem with that is that going from 7.5" to 7" is cradle will prob need modifying to take the
7" diff and shafts will likely be .25" short (though I doubt that would cause a problem). Very good how to on Reliant Scimitar forum as
relatively common mod on ss1's to fit sierra 7"LSD in place of open 7" fitted as std.
Mick
mark chandler
| posted on 25/6/17 at 07:22 AM |
Crown wheel and pinion are universal in the 7" range of diffs, I took a 3.14 push in CWP and swapped straight into a 3.65 bolt on LSD.
Dick
| posted on 25/6/17 at 01:55 PM |
Im 99.9% certain that the internals on the 7 and 7 1/2 diffs are identical and can be changed into either cassing
HappyFather
| posted on 25/6/17 at 02:52 PM |
Thank you for the replies!
Since there are no push-in LSD, this means that buying a lobro LSD case any ratio and then the 3.14 push-in I can get the most desired 3.14 LSD lobro
Now, let's go shopping!
