Author: Subject: Reg/rectifier wiring
Rob55
posted on 10/7/17 at 07:47 AM Reply With Quote
Can anyone advise where the positive and negative wires from the regulator should go to? I am using an MBE loom and FIA battery cut off. Surely they do not go direct to the battery. Also how heavy do the wires need to be?
(I know that the other 3 wires out of the reg/rec connect straight to the stator on the engine and in no particular order)
Thanks in advance
Rob
[Edited on 10/7/17 by Rob55]
CosKev3
posted on 10/7/17 at 09:33 AM Reply With Quote
Anywhere on your main power circuit/wiring connections,or direct to battery.
I've got mine going to my busbar's behind the dash,as this was the nearest place to connect it too.
Mines got a CB for protection.
Could go onto your main battery feed on the start relay/solenoid etc if that's easy to get to
[Edited on 10/7/17 by CosKev3]
Rob55
posted on 13/7/17 at 11:57 AM Reply With Quote
Great info, thank you
Mavrik
posted on 7/8/17 at 09:50 PM Reply With Quote
I run mine straight to my LiFePO4 battery now... Originally the -ve was earthed on the chassis & the +ve was via the starter relay...
I used 17amp cable (hardwired to the reg/rec)
[Edited on 7/8/17 by Mavrik]
My Other Rides:
HRC Limited Edition RR-7 Fireblade
350zed HR 313 Convertible
Mercedes-Benz SLK Kompressor
