Author: Subject: weber dcoe 40 problem
wandr
posted on 4/8/17 at 10:36 AM Reply With Quote
Hi all can any one help with this one, I have a pair of 40's on my car, was running fine and then had a starting issue where no fuel was coming through accelerator jets so wouldn't start, it had been laid up for a while, now have it running but it revs like mad with throttle closed any ideas?
Jenko
posted on 4/8/17 at 10:59 AM Reply With Quote
If it revs with the throttle closed then you have an air leak. I would check the rubber misab gaskets, and also the manifold to head gasket. if it's been laid up up the rubber can perish.
Also check needle valve is working.
MY BLOG - http://westfieldv8.blogspot.co.uk/
