axle
| posted on 30/9/17 at 01:56 PM |
Correct flywheel for Mt 75 with 2l Zetec
Hi All
I am planning to fit Zetec to my car I have the MT75 gearbox at the moment with the DOHC 8v but what fly wheel do I need as this need to match the
starter motor as well. I am hoping I can use my present clutch kit , can anyone shed some light over this please?
[Edited on 30/9/17 by axle]
Regards Axle
IVA passed 1st time thanks to the Forum members.
big_wasa
| posted on 30/9/17 at 05:33 PM |
You need the Zetec 1.8 or 2.0 flywheel.
You can use either the 220mm or the 240mm flywheel. The 2.0 always has the 1" 23 spline clutch. The 220mm could have two differant sizes for the
first motion shaft.
You then need either a spacer for the thrust bearing like Westfield or an extended clutch pivot like Gbs.
Starter is from the dohc.
[Edited on 30/9/17 by big_wasa]
axle
| posted on 30/9/17 at 07:52 PM |
Thanks for clearing that up I was just on time to get a 1.8 one they are much lighter than 2.0
Thanks again
Regards Axle
