westf27
posted on 26/10/17 at 06:39 PM |
Floor mount bias pedal box with cable clutch
Finishing off a part built Sylva Stylus.
It has a clutch cable to a type nine.
The clutch pedalfalls towards your feet
Should there be a stop on the pedal,a spring
Or is there something else to stop the pedal falling
Sure I can do something to stop it but wondered if there is
Something so simple I'm missing it
555
posted on 26/10/17 at 08:04 PM |
I just made a small angled stop from 25mm single , bolted through the floor
westf27
posted on 26/10/17 at 09:42 PM |
Thanks,as simple as that
Regards
Stevel
555
posted on 27/10/17 at 12:00 PM |
From memory I made a stop bracket from a small strip of Aluminium held in place by the brake pivot bolt. Worked fine for me - cheap and easy to do +
you can rotate it to adjust the stop point.
