Author: Subject: Caterham heated windscreen
matty h
posted on 9/12/17 at 09:07 PM Reply With Quote
Does anyone have a wiring diagram for wiring up the caterham heated screen up.
Matty
posted on 9/12/17 at 09:16 PM Reply With Quote
Would have thought it would have one live feed and an earth? Might be worth wiring through a relay .
scimjim
posted on 10/12/17 at 08:38 AM Reply With Quote
http://www.heatedwindscreen.com/acatalog/wireing_details.html
mackei23b
posted on 10/12/17 at 04:34 PM Reply With Quote
Here is the Caterham Wiring Diagram for a K series Car (up to 2006) : https://www.graduates.org.uk/docs/201626_EU3_wiring.pdf
No relay in the Caterham for the heated screen, fuse rated at 10A, but that is not to say that is good practice!
Ian
James24785
posted on 10/12/17 at 05:06 PM Reply With Quote
Aslong as the switch you're using is rated high enough, then you should be ok without a relay
That being said, personally I'd probably fit a relay
bi22le
posted on 10/12/17 at 08:30 PM Reply With Quote
Fit a relay, you would be mad not to.
The cost less than 1 and isolate the circuit from the rest of the car's switch and feed wiring.
Please read my ring story:
